you can try to play with the operating system and java settings to increase the max allowed open files …but… this is not a solution… most likely they will be peaked at the max again and you will get the same error.
something is happening and the open files are not being closed correctly (maybe?)
It could be an inherit bug within the http binding code (doesn’t close the connections properly or fast enough)
I am thinking that the combination of the http call with the JS transformation is opening too many files and may not be closing them correctly to free up resources.
Anyway, your plan is the best: wait for the binding to provide native sensors support
Stable builds are (should be) available in every repo so do not have an expiry. The RC has been left over from before we decided to keep milestone and RC builds in the testing repo. It’s only a “tag” that points to a single shared directory, so doesn’t take any more space.
If you want help, you mustn’t be so hesitant in giving information upfront.
What’s your HW ? If it’s a Pi or other low-mem ARM SBC then yes.
It’s using a lot more memory than 32bit JVM which you don’t have, this can result in all different kinds of problems. Either way, move to 32bit JVM. No point in using any 64bit one with openHAB.
Since this version I find these WARNING-Messages in the log file:
2018-11-25 17:04:05.868 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui_0.10.0.oh240M6 [148]] to http service
2018-11-25 17:04:05.993 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2018-11-25 17:04:06.121 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.10.0.oh240M6 [148], contextID=custom], with context-name:
2018-11-25 17:04:06.209 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.10.0.oh240M6 [148], contextID=custom]}
2018-11-25 17:04:06.639 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2018-11-25 17:04:06.795 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.10.0.oh240M6 [148], contextID=default], with context-name:
2018-11-25 17:04:07.043 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.10.0.oh240M6 [148], contextID=default]}
2018-11-25 17:04:08.103 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui.icon_0.10.0.oh240M6 [149]] to http service
2018-11-25 17:04:08.249 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2018-11-25 17:04:08.341 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.10.0.oh240M6 [149], contextID=default], with context-name:
2018-11-25 17:04:08.290 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/sitemaps/default/0502
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_1,2,33220692) has been shut down
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 18 more
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are:
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 18 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_1,2,33220692) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
... 18 more
2018-11-25 17:04:08.803 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.10.0.oh240M6 [149], contextID=default]}
2018-11-25 17:04:09.435 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.ui.dashboard_2.4.0.M6 [183]] to http service
2018-11-25 17:04:09.555 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2018-11-25 17:04:09.660 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.4.0.M6 [183], contextID=default], with context-name:
2018-11-25 17:04:09.743 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.4.0.M6 [183], contextID=default]}
Also this warning is new for me:
2018-11-25 10:57:58.280 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /start/favicon.ico
javax.servlet.ServletException: java.nio.channels.ClosedChannelException
Caused by: java.nio.channels.ClosedChannelException
at org.eclipse.jetty.util.IteratingCallback.close(IteratingCallback.java:427) ~[?:?]
at org.eclipse.jetty.server.HttpConnection.onClose(HttpConnection.java:507) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onClose(SslConnection.java:257) ~[?:?]
at org.eclipse.jetty.io.SelectorManager.connectionClosed(SelectorManager.java:341) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector$DestroyEndPoint.run(ManagedSelector.java:874) ~[?:?]
... 3 more
I’ve noticed my logs are full of these errors now. It’s as if sending OFF/ON to a dimmer item isn’t working nicely for logging. I’ve been away from home but just logged in to check some things for my wife and noticed them.
I have a lot of Lifx bulbs and a rule for each which sends ON/OFF to a switch item (that’s bound to the brightness channel) when it’s status goes ONLINE/OFFLINE.
rule "Turn on/off Living TV Light 1"
Thing "lifx:whitelight:livingtv1" changed
var status = ThingAction.getThingStatusInfo("lifx:whitelight:livingtv1").getStatus()
if (status.toString() == 'OFFLINE')
//logError("Debug", "Attempting to turn off light")
postUpdate(vLight_LivingTV1, OFF)
else {
vLight_LivingTV1.sendCommand(ON)
Error
2018-11-26 08:19:14.763 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:58) ~[?:?]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:53) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.util.LifxMessageUtil.kelvinToPercentType(LifxMessageUtil.java:98) ~[?:?]
at org.eclipse.smarthome.binding.lifx.handler.LifxLightHandler$CurrentLightState.updateColorChannels(LifxLightHandler.java:173) ~[?:?]
at org.eclipse.smarthome.binding.lifx.handler.LifxLightHandler$CurrentLightState.setColors(LifxLightHandler.java:146) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.LifxLightState.setColor(LifxLightState.java:119) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.LifxLightCurrentStateUpdater.handleLightStatus(LifxLightCurrentStateUpdater.java:176) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.LifxLightCurrentStateUpdater.handleResponsePacket(LifxLightCurrentStateUpdater.java:150) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.LifxLightCommunicationHandler.lambda$3(LifxLightCommunicationHandler.java:243) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:?]
at org.eclipse.smarthome.binding.lifx.internal.LifxLightCommunicationHandler.lambda$2(LifxLightCommunicationHandler.java:243) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
Before M6 I was on 2.3 stable and there were no errors. I’ll need to check when I’m home tonight/tomorrow whether the warnings in the log are just warnings and I can ignore them.
This one is an old one and I experience it also when:
stop OH2
start it immediately (within less than 5 seconds)
If I leave the service down for 10-15 secs and start it up again: this warn does not appear any more.
I don’t know what is causing it. Some say open browsers trying to reconnect to the Web UIs (so you need to let them timeout and then start the service)
this could also be related to open browsers.. not sure.. I don’t remember seeing this one before
To All coming from openHAB 2.3.0 to openHAB 2.4.0 Milestone 6:
Remember the breaking changes that 2.4 brings and deal with them (easy to handle):
Listing important changes for version 2.4.0:
Warning: Astro Binding: The 'kilometer' and 'miles' channels have been replaced by a new 'distance' channel
Warning: Jeelink Binding: The 'currentWatt' and 'maxWatt' channels have been replaced with 'currentPower' and 'maxPower' channels
Warning: WeatherUnderground Binding: A bridge has been added on top of the current things, you need to add a bridge containing your api-key.
Warning: ZWave Binding: Major changes have been merged to support features such as security. All things must be deleted and re-added. Refer to https://community.openhab.org/t/zwave-binding-updates/51080 for further information.
Warning: Synop Binding is now using UoM. 'wind-speed-ms' and 'wind-speed-knots' channels have been replaced by a single 'wind-speed' channel.
I have a range of Lifx lights. Colour, whites, and mini’s. The only rules I have running on them is the postUpdate of OFF/ON when the status changes. The Switch items are all bound only to the brightness channel, not temperature if that makes any difference.
For me, on M6 openHab process freezes regurarly.
I can’t say much about it, it randomly stops (there is no event in the log about it). When it stops I can’t even connect to the RPi on SSH. After a few minutes (30-40 minutes) the service is restarted by itself and it loads openHab again. Systemctl says it’s exited and the exit code is 1 (Failure).
Anyone knows how can I debug this?
