Hardware: CPUArchitecture: ARMv7 Processor rev 5 (v7l), Raspberry Pi 2 Model B Rev 1.1
RAM: 1GB
Storage: 32GB
OS: Raspbian GNU/Linux 9, Linux 4.19.66-v7+
Java Runtime Environment: ?
openHAB version: OH2.5.10-1
Issue of the topic: systeminfo cpu#load is blank.
I just upgraded from 2.4 to 2.5 . The cpu#load channel is available but empty. There is no cpu#load1, 5, and 15 channels shown under CPU group in Paper UI.
I uninstalled and re-installed the System Info Binding (binding-systeminfo - 2.5.10) but that did not help.
Thank you.
In Paper UI > Configuration > Things, I deleted the old thing as you had suggested. I then went into Inbox to create a new Local Computer thing from the SystemInfo binding.
This time the new thing only shows one channel: systeminfo:computer:openHABianPi:cpu#name under the CPU group. Other CPU channels are missing.
@opus@Bruce_Osborne,
Stupid question: Could I download an old 2.4 version .jar file (which had worked well before my upgrade to 2.5) and put it in /usr/share/openhab2/addons ? If yes, do you know the download link?
@opus, That was it! another newbie mistake. A very big THANK YOU to you.
I still have other errors related to wink:wink_hub_2, mqtt, and others but will open new threads if I cannot solve them myself. Upgrade is just never easy for me .
Hi, I have a question not related to this about the SystemInfo binding. Is it already possible to show multiple storage and/or drives with the binding? In the binding info it points to an issue created back in 2016 and no information is updated apparently after that (at least I did not found it and hoped I overseen it).
