OH 2.5.12 problems after debian upgrade from 11 -> 12
As title suggests. After Debian upgrade to 12, Openhab won’t start. Error message:
2023-08-13 21:11:33.490 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.IllegalStateException: Could not create a builder for the system bundle.
        at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:287)
        at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:87)
        at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
        at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
        at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
        at org.apache.karaf.main.Main.launch(Main.java:256)
        at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: org.osgi.framework.BundleException: Invalid manifest header Export-Package: "org.osgi.dto;version="1.0",org.osgi.resource;version="1.0",org.osgi.resource.dto;version="1.0";uses:="org.osgi.dto",org.osgi.framework;version="1.8",org.osgi.framework.dto;version="1.8";uses:="org.osgi.dto",org.osgi.framework.hooks.bundle;version="1.1";uses:="org.osgi.framework",org.osgi.framework.hooks.resolver;version="1.0";uses:="org.osgi.framework.wiring",org.osgi.framework.hooks.service;version="1.1";uses:="org.osgi.framework",org.osgi.framework.hooks.weaving;version="1.1";uses:="org.osgi.framework.wiring",org.osgi.framework.launch;version="1.2";uses:="org.osgi.framework",org.osgi.framework.namespace;version="1.1";uses:="org.osgi.resource",org.osgi.framework.startlevel;version="1.0";uses:="org.osgi.framework",org.osgi.framework.startlevel.dto;version="1.0";uses:="org.osgi.dto",org.osgi.framework.wiring;version="1.2";uses:="org.osgi.framework,org.osgi.resource",org.osgi.framework.wiring.dto;version="1.2";uses:="org.osgi.dto,org.osgi.resource.dto",org.osgi.service.condpermadmin;version="1.1.1";uses:="org.osgi.framework,org.osgi.service.permissionadmin",org.osgi.service.packageadmin;version="1.2";uses:="org.osgi.framework",org.osgi.service.permissionadmin;version="1.2",org.osgi.service.resolver;version="1.0";uses:="org.osgi.resource",org.osgi.service.startlevel;version="1.1";uses:="org.osgi.framework",org.osgi.service.url;version="1.0",org.osgi.util.tracker;version="1.5.1";uses:="org.osgi.framework",org.apache.karaf.version;version="4.2.7",org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version="4.2.7",org.apache.karaf.jaas.boot;uses:="javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework";version="4.2.7",org.apache.karaf.info;version="4.2.7",, org.apache.karaf.branding, sun.misc, org.apache.karaf.jaas.boot;uses:="javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework";version=4.2.7, org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=4.2.7, org.apache.karaf.diagnostic.core;uses:=org.osgi.framework;version=4.2.7, org.apache.karaf.diagnostic.core.common;uses:=org.apache.karaf.diagnostic.core;version=4.2.7"
        at org.eclipse.osgi.util.ManifestElement.parseHeader(ManifestElement.java:353)
        at org.eclipse.osgi.container.builders.OSGiManifestBuilderFactory.createBuilder(OSGiManifestBuilderFactory.java:85)
        at org.eclipse.osgi.storage.Storage.getBuilder(Storage.java:632)
        at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:273)
        ... 6 more
  • Platform information:
    • Hardware: x86_64/Intel(R) Core™ i3-7100T CPU @ 3.40GHz/4GB RAM
    • OS: Debian 12.1
    • Java Runtime Environment: openjdk version “17.0.8” 2023-07-18
    • openHAB version: 2.5.12
Hope this info is sufficient. I know I’m still running old OH. Is it not compatible anymore?
Sorry if that is true and I overlooked it.
Thank you!
openHAB versions below 4.0 do not run at Java 17! You need to downgrade your Java version to 8!
Thanks for hint. Once I selected the old alternative java, openhab started working.
update-alternatives --config java
Is it recommended to upgrade first to OH3 and then to OH4?
Thank you and br,
Either way it’s going to be a lot of work. I’m not sure there is any benefit in upgrading to 3 first.
