Hi @marcel_verpaalen ,
What are the steps for adding local support for the “Smartmi Standing Fan 3 (zhimi.fan.za5)” in the OH 2.5 binding?
I see it as experimental in the 3.2 binding version.
Thank you.
Thank you.
I have the token.
Do I need to add the thing manually?
If I let it discover with my login details I get an unsupported device thing added.
"deviceMapping": {
"id": [
"zhimi.fan.za5"
"propertyMethod": "get_properties",
"maxProperties": 1,
"channels": [
"property": "on",
"siid": 2,
"piid": 1,
"friendlyName": "Fan - Power",
"channel": "on",
"type": "Switch",
"refresh": true,
"actions": [
"command": "set_properties",
"parameterType": "ONOFFBOOL"
"category": "switch",
"tags": [
"Switch"
"property": "fan-level",
"siid": 2,
"piid": 2,
"friendlyName": "Fan - Fan Level",
"channel": "fan_level",
"type": "Number",
"stateDescription": {
"options": [
"value": "1",
"label": "Level 1"
"value": "2",
"label": "Level 2"
"value": "3",
"label": "Level 3"
"value": "4",
"label": "Level 4"
"refresh": true,
"actions": [
"parameterType": "NUMBER"
"readmeComment": "Value mapping `[\"1\"\u003d\"Level 1\",\"2\"\u003d\"Level 2\",\"3\"\u003d\"Level 3\",\"4\"\u003d\"Level 4\"]`"
"property": "horizontal-swing",
"siid": 2,
"piid": 3,
"friendlyName": "Fan - Horizontal Swing",
"channel": "horizontal_swing",
"type": "Switch",
"refresh": true,
"actions": [
"property": "horizontal-angle",
"siid": 2,
"piid": 5,
"friendlyName": "Fan - Horizontal Angle",
"channel": "horizontal_angle",
"type": "Number",
"minimum": 30,
"maximum": 120,
"step": 1,
"pattern": "%.0f"
"refresh": true,
"actions": [
"parameterType": "STRING"
"property": "mode",
"siid": 2,
"piid": 7,
"friendlyName": "Fan - Mode",
"channel": "mode",
"type": "Number",
"options": [
"value": "0",
"label": "Natural Wind"
"value": "1",
"label": "Straight Wind"
"refresh": true,
"actions": [
"readmeComment": "Value mapping `[\"0\"\u003d\"Natural Wind\",\"1\"\u003d\"Straight Wind\"]`"
"property": "off-delay",
"siid": 2,
"piid": 10,
"friendlyName": "Fan - Power Off Delay",
"channel": "off_delay",
"type": "Number",
"minimum": 0,
"maximum": 36000,
"step": 1,
"pattern": "%.0f"
"refresh": true,
"actions": [
"property": "anion",
"siid": 2,
"piid": 11,
"friendlyName": "Fan - Anion",
"channel": "anion",
"type": "Switch",
"refresh": true,
"actions": [
"property": "physical-controls-locked",
"siid": 3,
"piid": 1,
"friendlyName": "Physical Control Locked - Physical Control Locked",
"channel": "physical_controls_locked",
"type": "Switch",
"refresh": true,
"actions": [
"property": "brightness",
"siid": 4,
"piid": 3,
"friendlyName": "Indicator Light - Brightness",
"channel": "brightness",
"type": "Number:Dimensionless",
"unit": "percentage",
"minimum": 0,
"maximum": 100,
"step": 1,
"pattern": "%.0f %unit%"
"refresh": true,
"actions": [
"category": "light",
"tags": [
"Control",
"Light"
"property": "alarm",
"siid": 5,
"piid": 1,
"friendlyName": "Alarm - Alarm",
"channel": "alarm",
"type": "Switch",
"refresh": true,
"actions": [
"property": "relative-humidity",
"siid": 7,
"piid": 1,
"friendlyName": "Environment - Relative Humidity",
"channel": "relative_humidity",
"minimum": 0,
"maximum": 100,
"step": 1,
"pattern": "%.0f %unit%",
"readOnly": true
"refresh": true,
"actions": [],
"tags": [
"Measurement",
"Humidity"
"property": "temperature",
"siid": 7,
"piid": 7,
"friendlyName": "Environment - Temperature",
"channel": "temperature",
"type": "Number:Temperature",
"unit": "celsius",
"minimum": -30,
"maximum": 100,
"pattern": "%.1f %unit%",
"readOnly": true
"refresh": true,
"actions": [],
"category": "temperature",
"tags": [
"Setpoint",
"Temperature"
"property": "button-press",
"siid": 6,
"piid": 1,
"friendlyName": "Custom Service - Button Press",
"channel": "button_press",
"type": "Number",
"readOnly": true,
"options": [
"value": "1",
"label": "power"
"value": "2",
"label": "swing"
"value": "0",
"label": "No Button Pressed"
"refresh": true,
"actions": [],
"readmeComment": "Value mapping `[\"1\"\u003d\"power\",\"2\"\u003d\"swing\",\"0\"\u003d\"No Button Pressed\"]`"
"property": "battery-state",
"siid": 6,
"piid": 2,
"friendlyName": "Custom Service - Battery State",
"channel": "battery_state",
"type": "Switch",
"readOnly": true
"refresh": true,
"actions": []
"property": "speed-now",
"siid": 6,
"piid": 4,
"friendlyName": "Custom Service - Speed Now",
"channel": "speed_now",
"type": "Number",
"minimum": 0,
"maximum": 3000,
"step": 1,
"pattern": "%.0f",
"readOnly": true
"refresh": true,
"actions": []
"property": "ac-state",
"siid": 6,
"piid": 5,
"friendlyName": "Custom Service - Ac State",
"channel": "ac_state",
"type": "Switch",
"readOnly": true
"refresh": true,
"actions": []
"property": "speed-level",
"siid": 6,
"piid": 8,
"friendlyName": "Custom Service - Speed Level",
"channel": "speed_level",
"unit": "percent",
"minimum": 1,
"maximum": 100,
"step": 1,
"refresh": true,
"actions": [
"experimental": true
Is it compatible with OH2.5 binding? Can I just use it or does it need adjustments?
In case it is compatible, I copied the json file to /misc/miio folder but I get warning in my log about RSSI# etc…
needs to be "type": "Number",
) to normal numbers. Keep in mind that everything in the ‘statedescription’ is not understood in by the 2.5. (it will most likely just ignore it)Note: It can’t break anything if you are trying… worse that can happen that channels don’t work…
