OH 3.1.0, EnOcean, Eltako TF61L warnings after teachin
Hi there,
still working on my OH3.1.0 setup, adding switch for switch, some of them already in stock quite a while e.g. Eltako TF61L …
I replaced an EnOcean classic device with one of them, because they are bidirectional. First one I struggle heavily after teach in, very unreliable, debug did show different EnoID on its response … very strange …
Replaced that one quickly for test purposes with another one, got it teached in, does work better, albeit not perfect. Debug messages on, after teachin were proper … but very fast I get those warning messages, means not just in DEBUG level, also on DEFAULT:
2021-08-12 22:57:50.417 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel teachInCMD is linked although the handler was already disposed.
2021-08-12 22:57:50.420 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel contact is linked although the handler was already disposed.
2021-08-12 22:57:50.422 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel rollershutter is linked although the handler was already disposed.
2021-08-12 22:57:50.424 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel lastReceived is linked although the handler was already disposed.
2021-08-12 22:57:50.426 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel generalSwitch is linked although the handler was already disposed.
2021-08-12 22:57:50.427 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel repeatCount is linked although the handler was already disposed.
2021-08-12 22:57:50.429 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel rssi is linked although the handler was already disposed.
2021-08-12 22:57:50.431 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel teachInCMD is linked although the handler was already disposed.
2021-08-12 22:57:50.433 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel contact is linked although the handler was already disposed.
2021-08-12 22:57:50.434 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel rollershutter is linked although the handler was already disposed.
2021-08-12 22:57:50.436 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel lastReceived is linked although the handler was already disposed.
2021-08-12 22:57:50.438 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel generalSwitch is linked although the handler was already disposed.
2021-08-12 22:57:50.439 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel repeatCount is linked although the handler was already disposed.
2021-08-12 22:57:50.441 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseActuatorHandler of thing enocean:centralCommand:gtwy:0514Bxxx tried checking if channel rssi is linked although the handler was already disposed.
Any idea were they point to and howto get rid of them?
Cheers
Try to clean your cache via:
sudo systemctl stop openhab.service
openhab-cli clean-cache
sudo systemctl start openhab.service
Hey, thanks for the reply :+1:t2: stumbled also about that cache thing, but looking for other topics …
To make it short that did help here. Since I’m actually playing heavily in my things and items files, I might do that from time to time, till I’m finished with everything.
Maybe wouldn’t have needed to exchange the two Eltako Aktors doing that before, maybe re-teachin the first one …
Looks like, I should have done that cache cleaning after I deleted that EnOcean ClassicDevice out of configuration. That Eltako TF61 I exchanged yesterday, does work properly now, teached it in for test purpose quickly … response did show correct EnoID today …
Nice to hear that it is working now. I also got this error several times setting up my nearly 100 enocean devices :sweat_smile:
