OH 3.1.0 InfluxDB stopped working after update to 1.8.7-1
I have the same problem with 1.8.10.
None of the workarounds/suggestions work.
Anybody an idea what to do next ?
Thx
DirkB
Hello I just did an new apt-get update/upgrade and got the following, with errors
dpkg: could not open log '/var/log/dpkg.log': Read-only file system
dpkg: error processing package grafana (--configure):
 installed grafana package post-installation script subprocess returned error exit status 1
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
Errors were encountered while processing:
 grafana
Could this be the problem, that causes that grafana fails to start now?
Here the settings of dpkg.log
openhabian@hab3:~ $ ls /var/log/dpkg.log -l
-rw-r--r-- 1 root root 0 Oct 16 00:00 /var/log/dpkg.log
Is it normal that this file is not writeable? How is the correct flag setting of this file?
Here the complete log
openhabian@hab3:~ $ sudo apt-get update
[sudo] password for openhabian:
Hit:1 http://davesteele.github.io/comitup/repo comitup InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Hit:5 https://packages.grafana.com/oss/deb stable InRelease
Hit:6 https://repos.influxdata.com/debian buster InRelease
Hit:7 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Reading package lists... Done
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB.UTF-8) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
openhabian@hab3:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  triggerhappy
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  grafana
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 63.2 MB of archives.
After this operation, 39.9 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 https://packages.grafana.com/oss/deb stable/main armhf grafana armhf 8.2.2 [63.2 MB]
Fetched 63.2 MB in 9s (6,693 kB/s)
Reading changelogs... Done
(Reading database ... 59258 files and directories currently installed.)
Preparing to unpack .../grafana_8.2.2_armhf.deb ...
Unpacking grafana (8.2.2) over (8.2.1) ...
Setting up grafana (8.2.2) ...
Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
chown: changing ownership of '/var/log/grafana/grafana.log': Read-only file system
chown: changing ownership of '/var/log/grafana/grafana.log.2021-10-15.001': Read-only file system
chown: changing ownership of '/var/log/grafana': Read-only file system
 grafana
Updating FireMotD available updates count ...
W: Problem unlinking the file /var/log/apt/eipp.log.xz - FileFd::Open (30: Read-only file system)
W: Could not open file /var/log/apt/eipp.log.xz - open (17: File exists)
W: Could not open file '/var/log/apt/eipp.log.xz' - EIPP::OrderInstall (17: File exists)
W: Could not open file '/var/log/apt/term.log' - OpenLog (30: Read-only file system)
E: Sub-process /usr/bin/dpkg returned an error code (1)
openhabian@hab3:~ $
I just did also the “sudo apt autoremove” and this also runs into errors
openhabian@hab3:~ $ sudo apt autoremove
The following packages will be REMOVED:
  triggerhappy
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 97.3 kB disk space will be freed.
(Reading database ... 59261 files and directories currently installed.)
Removing triggerhappy (0.5.0-1) ...
Warning: Stopping triggerhappy.service, but it can still be activated by:
  triggerhappy.socket
Processing triggers for man-db (2.8.5-2) ...
 grafana
I just also did now an sudo openhabian-config which also has errors and a “fix Permission” which also runs with errors
openhabian@hab3:~ $ sudo openhabian-config
2021-10-24_13:51:55_CEST [openHABian] Checking for root privileges... OK
2021-10-24_13:51:55_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-10-24_13:51:55_CEST [openHABian] openHABian configuration tool version: [main]{2021-10-14T12:07:14+02:00}(9bbfa35)
2021-10-24_13:51:55_CEST [openHABian] Checking for changes in origin branch main... Updates available... UPDATING
2021-10-24_13:52:02_CEST [openHABian] Updating myself... mv: cannot stat '/opt/openhabian/docs/NEWS.md': No such file or directory
OK - Commit history (oldest to newest):
ebf77f4 - Bump actions/checkout from 2.3.4 to 2.3.5 (#1606) (6 days ago) <dependabot[bot]> E
 .github/workflows/bats-action.yml         | 4 ++--
 .github/workflows/build-action.yml        | 4 ++--
 .github/workflows/installation-action.yml | 8 ++++----
 .github/workflows/shellcheck-action.yml   | 2 +-
 4 files changed, 9 insertions(+), 9 deletions(-)
4eb12b2 - cosmetics (6 days ago) <Markus Storm> E
 functions/vpn.bash | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
67b918d - cosmetics (4 days ago) <Markus Storm> E
 functions/menu.bash | 2 +-
3e21da6 - cosmetics (4 days ago) <Markus Storm> E
 build-image/openhabian.conf | 2 +-
789b855 - cosmetics (4 days ago) <Markus Storm> E
 build-image/openhabian.pi-raspios64beta.conf | 2 +-
78af774 - cosmetics (4 days ago) <Markus Storm> E
 build-image/openhabian.pi-raspios32.conf | 2 +-
bb2cb4b - Update menu.bash (4 days ago) <Markus Storm> E
087e661 - fix unattended restore to use argument as filename (16 hours ago) <Markus Storm> E
 functions/backup.bash | 2 +-
63d725b - no group+s permission on files (just on dirs) (5 hours ago) <Markus Storm> E
 functions/system.bash | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
65f82c4 - Fix RPi generating random MAC address on boot (#1608) (5 hours ago) <Markus Storm> E
 functions/wifi.bash                                      | 1 +
 includes/generic/100-disable-wifi-mac-randomization.conf | 5 +++++
 2 files changed, 6 insertions(+)
855cb4e - fix chmod fix (5 hours ago) <Markus Storm> E
 functions/system.bash | 2 +-
openHABian configuration tool successfully updated.
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates... OK
2021-10-24_13:52:08_CEST [openHABian] Checking for root privileges... OK
2021-10-24_13:52:08_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-10-24_13:52:08_CEST [openHABian] openHABian configuration tool version: [main]{2021-10-24T08:54:39+02:00}(855cb4e)
2021-10-24_13:52:08_CEST [openHABian] Checking for changes in origin branch main... OK
2021-10-24_13:52:14_CEST [openHABian] Switching to branch main... OK
2021-10-24_13:53:00_CEST [openHABian] Updating Linux package information... OK
2021-10-24_13:53:00_CEST [openHABian] Applying file permissions recommendations... FAILED (openhab folders)
FAILED (folders)
FAILED (setgid backups folder)
FAILED (unattended upgrades logdir)
FAILED (openhab log)
OK
2021-10-24_13:53:09_CEST [openHABian] Checking for default openHABian username:password combination... OK
2021-10-24_13:53:09_CEST [openHABian] We hope you got what you came for! See you again soon ;)
openhabian@hab3:~ $
After the fix permisson the flags changed
openhabian@hab3:~ $ ls /var/log/dpkg* -l
-rw-rw-r-- 1 root root     0 Oct 16 00:00 /var/log/dpkg.log
-rw-rwSr-- 1 root root 38470 Oct 15 19:56 /var/log/dpkg.log.1
-rw-rw-r-- 1 root root  2218 Jul  1 22:29 /var/log/dpkg.log.2.gz
I did now an other apt-get update /upgrade this tim error free
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:4 https://packages.grafana.com/oss/deb stable InRelease
Hit:5 https://repos.influxdata.com/debian buster InRelease
Hit:6 https://deb.nodesource.com/node_14.x buster InRelease
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
Restarting grafana-server service... OK
Fixing the permissions ended in
2021-10-24_14:18:33_CEST [openHABian] Checking for root privileges... OK
2021-10-24_14:18:33_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-10-24_14:18:33_CEST [openHABian] openHABian configuration tool version: [main]{2021-10-24T08:54:39+02:00}(855cb4e)
2021-10-24_14:18:33_CEST [openHABian] Checking for changes in origin branch main... OK
2021-10-24_14:18:36_CEST [openHABian] Switching to branch main... OK
2021-10-24_14:18:46_CEST [openHABian] Updating Linux package information... OK
2021-10-24_14:18:46_CEST [openHABian] Applying file permissions recommendations... FAILED (setgid backups folder)
OK
2021-10-24_14:19:22_CEST [openHABian] Checking for default openHABian username:password combination... OK
2021-10-24_14:19:22_CEST [openHABian] We hope you got what you came for! See you again soon ;)
Wondering if it is somehow caused by openhabian-config ?
I managed to get InfluxDB working after a manual re-install (not via openhabian-config).
All was fine.
Untill I did a 50.Backup Openhab config in the openhabian-config tool… after reboot, same problem again.
Then I realised that this is the second time I had this phenomena (InfluxDb no longer working after 50. Backup Openhab config) …
What I did with openhabian was
02 Upgrade System (which was automatically asked for on starting openhabian conf)
After an reboot an relogin I noticed the I had lots of apt updates open, so I started apt-get update + apt-get upgrade and rebooted again.
Then I noticed that influxdb is not working anymore.
apt reinstall influxdb
did not work for me.
The issues seems to be very common if I read through the internet. But no one has a real solutuion for it. Additional I have the problem that I allready got the version “1.8.10” all other threads at the moment have the problem with “1.8.9”
I have doubts at the moment with doing a complete new install of openhabian as I think I will again run into this trouble. And I hope at the moment to find somewhere a solution which fixes the problem.
I think it is a problem of missing/wrong permission, group or users.
I have no idea why this does not work and if it is important for influxDB
As far as I understand you use version
it looks like there is an update available since yesterday:
I am not sure if this will fix your problem with:
according to the description it could be.
Looking at messages like
it looks like there is a problem with the filesystem. Strange that it seems that it was fixed by fix permissions menu entry.
I am now on openHABian Configuration Tool — [main]{2021-10-24T08:54:39+02:00}(855cb4e)
Influx is 1.8.10…
When I did sudo apt reinstall influxdb, followed by
sudo systemctl restart influxdb, then Influxdb was running again :grinning:, untill I did a sudo reboot then the same problem came back :grimacing:.
I also confirm that Applying file permissions recommendations... FAILED (setgid backups folder)
is there anything mentioned in journalctl output about the root cause like missing directory of missing permissions after the reboot ?
journalctl output :
-- A stop job for unit influxdb.service has finished.
-- The job identifier is 11072 and the job result is done.
Oct 26 10:39:37 openhabian systemd[1]: influxdb.service: Start request repeated too quickly.
Oct 26 10:39:37 openhabian systemd[1]: influxdb.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit influxdb.service has entered the 'failed' state with result 'exit-code'.
Oct 26 10:39:37 openhabian systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
-- Subject: A start job for unit influxdb.service has failed
-- A start job for unit influxdb.service has finished with a failure.
-- The job identifier is 11072 and the job result is failed.
Oct 26 10:39:39 openhabian systemd[1]: systemd-timesyncd.service: Succeeded.
-- Subject: Unit succeeded
Applying file permissions recommendations... FAILED (setgid backups folder) is the result when selecting Fix File Permissions in Openhabian-config tool
This
just shows that there are too many trials to start the service.
Unfortunately I do not see any hint about the root cause why the individual trials failed.
As there is nothing shown in journalctl output is there may be something shown in
/var/log/syslog or in /var/log/influxdb/influxdb.log
Oct 28 14:48:57 openhabian systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Oct 28 14:48:57 openhabian influxd-systemd-start.sh[935]: /usr/lib/influxdb/scripts/influxd-systemd-start.sh: line 5: /var/lib/influxdb/influxd.pid: Permission denied
Oct 28 14:48:57 openhabian systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
Oct 28 14:48:57 openhabian systemd[1]: influxdb.service: Failed with result 'exit-code'.
Oct 28 14:48:57 openhabian systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
have a look to the directory and file permissions of ( following lines show how it should look like ):
ls -ld /var/lib/influxdb /var/lib/influxdb/influxd.pid
drwxr-xr-x 1 influxdb influxdb 4096 Oct 16 23:10 /var/lib/influxdb
-rw-r--r-- 1 influxdb influxdb    5 Oct 16 23:10 /var/lib/influxdb/influxd.pid
Either the directory belongs to root or the file belongs to root and the pid file cannot be created by the influxdb user. It looks like this seems to be the reason for aborting the startup of influxdb.
It could be that because of a manual start as user root file or directory were created with root’s permissions.
Wolfang, first, thank you very much for your support so far.
I’m a semi-noob, meaning I know a few linux commands but I don’t know how to troubleshoot this kind of problems… :innocent:
I can confirm that the influxdb directory was owned by root as you suggested…
ls: cannot access '/var/lib/influxdb/influxd.pid': No such file or directory
drwxr-sr-x 1 root root 4096 Oct 29 11:21 /var/lib/influxdb
When I chown it to influxdb, this did not solve the problem.
But when again I do sudo apt reinstall influxdb then this solves the issue …
Directory /var/lib/influxdb is then also owned by influxdb as you suggested and everything works…
only untill i do a sudo reboot. Then the same problem comes back and strangely the /var/lib/influxdb folder is again owned by root !!!
Am I missing something here about rebooting? Should I first stop all services like openhab, influxdb, grafana and then reboot ? … I’m still lost :roll_eyes:
Or could it be that installing the Influxdb addon in openhab (which I also did before the reboot) changes the directory owner to root ?
the addon is not the problem.
Do you run openhabian ? Do you use zram ?
I can fully confirm that behavior.
I did today a apt-get update + apt-get upgrade. → Still not working.
I opened openhabian-conf → the openhabian changes to “main” where applied → influxdb still not working.
sudo reboot → influx stil not working
After
influxdb started to work again → I am happy that I did not have reinstalled openhabian
influxdb stopped working again, so I now made an apt reinstall influxdb followed by the restart and I leave my system for the moment.
I am running openhabian
###############  openhabian  ##################################################
##        Ip = 192.168.1.205
##   Release = Raspbian GNU/Linux 10 (buster)
##    Kernel = Linux 5.10.63-v7l+
##  Platform = Raspberry Pi 4 Model B Rev 1.4
##    Uptime = 0 day(s). 0:0:27
## CPU Usage = 50.25% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
##  CPU Load = 1m: 1.32, 5m: 0.32, 15m: 0.11
##    Memory = Free: 6.77GB (87%), Used: 0.99GB (13%), Total: 7.76GB
##      Swap = Free: 2.43GB (100%), Used: 0.00GB (0%), Total: 2.43GB
##      Root = Free: 218.73GB (97%), Used: 6.18GB (3%), Total: 234.48GB
##   Updates = 0 apt updates available.
##  Sessions = 1 session(s)
## Processes = 140 running processes of 32768 maximum processes
                          _   _     _     ____   _
  ___   ___   ___   ___  | | | |   / \   | __ ) (_)  ____   ___
 / _ \ / _ \ / _ \ / _ \ | |_| |  / _ \  |  _ \ | | / _  \ / _ \
| (_) | (_) |  __/| | | ||  _  | / ___ \ | |_) )| || (_) || | | |
 \___/|  __/ \___/|_| |_||_| |_|/_/   \_\|____/ |_| \__|_||_| | |
      |_|                          3.1.0 - Release Build
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://hab3:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
I am using the main branch
You are currently using the "main" openHABian environment version.                     │
                                             │ The openHABian version to contain the very latest code for openHAB 3 is called "main". │
                                             │ This is providing you with the latest (openHAB3!) features but less people have tested │
                                             │ it so it is a little more likely that you run into errors.                             │
                                             │ You can step back a little and switch to use the stable version now called "openHAB3". │
                                             │ You can switch at any time by selecting this menu option again or by setting the       │
                                             │ 'clonebranch=' parameter in '/etc/openhabian.conf'.                                    │
                                             │    ( ) openHAB3  recommended standard version of openHABian (openHAB 3)                │
                                             │    (*) main      very latest version of openHABian (openHAB 3)                         │
                                             │    ( ) stable    old version of openHABian (openHAB 2)                                 │
                                             │                        <Ok>                            <Cancel>                        │
and I have no idea how to find out if I use ZRAM or not. My RPI 4 boots directly from an SSD I have no SD-Card in the slot.
I hope anybody is capable to find out why some of us run into this problem.
As far as I understand you will see devices like /dev/zram* in case zram is enabled and used.
Besides that you will have entries in /etc/ztab which describe how different directories are managed/bound.
Also the output of mount | grep zram whill show entries in case zram is in use.
The output of this
openhabian@hab3:~ $  mount | grep zram
/dev/sda2 on /opt/zram/persistence.bind type ext4 (rw,noatime)
/dev/zram1 on /opt/zram/zram1 type ext4 (rw,noatime)
overlay1 on /var/lib/openhab/persistence type overlay (rw,relatime,lowerdir=/opt/zram/persistence.bind,upperdir=/opt/zram/zram1/upper,workdir=/opt/zram/zram1/workdir,redirect_dir=on)
/dev/sda2 on /opt/zram/influxdb.bind type ext4 (rw,noatime)
/dev/zram2 on /opt/zram/zram2 type ext4 (rw,noatime)
overlay2 on /var/lib/influxdb type overlay (rw,relatime,lowerdir=/opt/zram/influxdb.bind,upperdir=/opt/zram/zram2/upper,workdir=/opt/zram/zram2/workdir,redirect_dir=on)
/dev/sda2 on /opt/zram/log.bind type ext4 (rw,noatime)
/dev/zram3 on /opt/zram/zram3 type ext4 (rw,noatime)
overlay3 on /var/log type overlay (rw,relatime,lowerdir=/opt/zram/log.bind,upperdir=/opt/zram/zram3/upper,workdir=/opt/zram/zram3/workdir,redirect_dir=on)
the “ls” output is
openhabian@hab3:~ $ ls /dev/zram* -l
brw-rw---- 1 root disk 254, 0 Oct 30 15:52 /dev/zram0
brw-rw---- 1 root disk 254, 1 Oct 30 15:52 /dev/zram1
brw-rw---- 1 root disk 254, 2 Oct 30 15:52 /dev/zram2
brw-rw---- 1 root disk 254, 3 Oct 30 15:52 /dev/zram3
Entries of ztab
# swap  alg             mem_limit       disk_size       swap_priority   page-cluster    swappiness
swap    lzo-rle         200M            450M            75              0               80
# dir   alg             mem_limit       disk_size       target_dir                      bind_dir
dir     zstd            150M            350M            /var/lib/openhab/persistence    /persistence.bind
dir     zstd            150M            350M            /var/lib/influxdb               /influxdb.bind
# log   alg             mem_limit       disk_size       target_dir              bind_dir                oldlog_dir
log     zstd            200M            450M            /var/log                /log.bind
Yes, ZRAM is enabled in your case.
Content of /etc/ztab describes how you can stop it.
I then would do the reinstall of inflxudb; start the zram service again and then try a reboot.
In case that does not help you may add an entry in /usr/lib/influxdb/scripts/influxdb.service ( ExecStartPre=/usr/bin/chown -R influxdb:influxdb /var/lib/influxdb ).
Create a backup of the original file in case that does not work and you would like to go back to the original version of the file.
Thank you this solved my problem.
I did the follwoing:
sudo zram-config "stop"
sudo systemctl start zram-config.service
sudo reboot
The restart influxdb I did, because after the restart of the zram-configservice it did not run.
Now after the reboot everything is working like a few weeks ago.
Thank you very much for helping me to solve that nasty issue.
I’m having similar problems. But in my case after few hours of working I see that everything stops writing data to influx.
I see this on grafana that data is no longer writing to database.
I updated everything, reinstalled influxdb but still after about 18h it stops writing data?
Today it was at 7:20:30. After this time there is no data.
I have checked logs: daemon.log:
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: bits received from HRNG source: 600064
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: bits sent to kernel pool: 543072
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: entropy added to kernel pool: 543072
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2 successes: 30
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2 failures: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2(2001-10-10) Poker: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2(2001-10-10) Runs: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2(2001-10-10) Long run: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: HRNG source speed: (min=326.872; avg=473.195; max=494.212)Kibits/s
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: FIPS tests speed: (min=8.997; avg=23.060; max=31.371)Mibits/s
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: Lowest ready-buffers level: 2
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: Entropy starvations: 0
Nov 10 07:20:10 openHABianDevice rngd[389]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Nov 10 07:22:47 openHABianDevice karaf[8583]: Exception in thread "OH-items-2687" java.io.IOError: java.io.EOFException
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.Volume$FileChannelVol.getByte(Volume.java:1000)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.Volume.getUnsignedShort(Volume.java:109)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.StoreWAL.longStackGetPage(StoreWAL.java:1046)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.StoreWAL.longStackTake(StoreWAL.java:913)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.StoreDirect.freePhysTake(StoreDirect.java:1098)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.StoreDirect.physAllocate(StoreDirect.java:666)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.StoreWAL.update(StoreWAL.java:404)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.Caches$HashTable.update(Caches.java:270)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.EngineWrapper.update(EngineWrapper.java:63)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.BTreeMap.put2(BTreeMap.java:707)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.BTreeMap.put(BTreeMap.java:643)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.openhab.persistence.mapdb.internal.MapDbPersistenceService.store(MapDbPersistenceService.java:186)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.openhab.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:152)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.openhab.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:473)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.openhab.core.items.GenericItem.lambda$1(GenericItem.java:259)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at java.base/java.lang.Thread.run(Thread.java:829)
Nov 10 07:22:47 openHABianDevice karaf[8583]: Caused by: java.io.EOFException
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.Volume$FileChannelVol.readFully(Volume.java:947)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011at org.mapdb.Volume$FileChannelVol.getByte(Volume.java:997)
Nov 10 07:22:47 openHABianDevice karaf[8583]: #011... 17 more
I did a upgrade some days ago but hadn´t done a reboot after that.
Today i made a reboot and InfluxDB stopped working.
InfluxDB 1.8.10-1 was installed with the upgrade and i found several threads with issues.
The workarounds didn´t worked for me although the new version should already fix the problems.
I finally had enough and installed 1.8.5-1 manually.
That´s not the best solution but i just don´t want to troubleshoot this for several hours…
