OH 3.1 Snapshot throws error when executing rules
  • Platform information:
    • Hardware: RaspberryPi4+
    • OS: javaVersion: 11.0.10
      javaVendor: Azul Systems, Inc.
      javaVendorVersion: Zulu11.45+27-CA
      osName: Linux
      osVersion: 5.10.11-v7l+
      osArchitecture: arm
      availableProcessors: 4
      freeMemory: 872063736
      totalMemory: 1038286848
    • openHAB version: version: 3.1.0 “Build #2237
since a week I receive error message when certain rules are executed.
As an example here is this rule:
  val  heute = ZonedDateTime.now()
  logInfo("TEST Datum","Heute: "+heute)
  val Start_Ferien = (Schulferiencalovode_StartdesaktuellenEintrags.state as DateTimeType).getZonedDateTime()
  val Ende_Ferien = (Schulferiencalovode_EndedesaktuellenEintrags.state as DateTimeType).getZonedDateTime()
  logInfo("FERIEN","Anfang: "+Start_Ferien)
  logInfo("FERIEN","Ende: "+Ende_Ferien)
  if (FeiertageHamburg_StartdesaktuellenEintrags.state != UNDEF) {
    val Start_Feiertag = (FeiertageHamburg_StartdesaktuellenEintrags.state as DateTimeType).getZonedDateTime()
    val Ende_Feiertag = (FeiertageHamburg_EndedesaktuellenEintrags.state as DateTimeType).getZonedDateTime()
    logInfo("FEIERTAG","Anfang: "+Start_Feiertag)
    logInfo("FEIERTAG","Ende: "+Ende_Feiertag)
  } else {
    val Start_Feiertag = (FeiertageHamburg_StartdesnachstenEintrags.state as DateTimeType).getZonedDateTime()
    val Ende_Feiertag = (FeiertageHamburg_EndedesnachstenEintrags.state as DateTimeType).getZonedDateTime()
    logInfo("FEIERTAG","Kein Feiertag! Nächster Feiertag: "+FeiertageHamburg_TiteldesnachstenEintrags.state+" - "+Start_Feiertag)
  if (heute >= Start_Ferien && heute < Ende_Ferien)
    logInfo("WECKLICHT","Kein Wecklicht - "+Schulferiencalovode_TiteldesaktuellenEintrags.state)
  else {
    logInfo("WECKLICHT","Keine Ferien!")
    if (schalter_4.state == ON) {
      schalter_4.sendCommand(OFF)
    } else if (wecklicht.state == ON && helligkeit_2.state < 10)
      schalter_4.sendCommand(ON)
As soon as the rule is executed (with manual start as well) following error comes up in the log (at least twice):
2021-03-10 08:56:19.956 [INFO ] [ext.common.types.util.TypeReferences] - Couldn't find JvmType for name 'org.openhab.core.model.script.actions.Semantics' in context org.eclipse.xtext.xbase.resource.BatchLinkableResource@31d0f uri='__synthetic0.09649417891683798.script'
java.lang.IllegalStateException: Resource has not been loaded
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByClass(ReflectionTypeProvider.java:200) ~[bundleFile:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByClass(ReflectionTypeProvider.java:151) ~[bundleFile:?]
	at org.eclipse.xtext.common.types.access.reflect.ReflectionTypeProvider.findTypeByName(ReflectionTypeProvider.java:88) ~[bundleFile:?]
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:256) [bundleFile:?]
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:233) [bundleFile:?]
	at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getTypes(ImplicitlyImportedFeatures.java:82) [bundleFile:?]
	at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getExtensionClasses(ImplicitlyImportedFeatures.java:76) [bundleFile:?]
	at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.newSession(XbaseBatchScopeProvider.java:121) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:164) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:140) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:81) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:58) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:54) [bundleFile:?]
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:38) [bundleFile:?]
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:135) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:54) [bundleFile:?]
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:70) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:72) [bundleFile:?]
	at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:166) [bundleFile:?]
	at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:505) [bundleFile:?]
	at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:162) [bundleFile:?]
	at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:75) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.validate(ScriptEngineImpl.java:177) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.getValidationErrors(ScriptEngineImpl.java:181) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.parseScriptIntoXTextEObject(ScriptEngineImpl.java:147) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.ScriptEngineImpl.newScriptFromString(ScriptEngineImpl.java:111) [bundleFile:?]
	at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:126) [bundleFile:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) [bundleFile:?]
	at java.util.Optional.ifPresent(Optional.java:183) [?:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1031) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1047) [bundleFile:?]
	at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:322) [bundleFile:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) [bundleFile:1.0.9]
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) [bundleFile:1.0.9]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) [bundleFile:1.0.9]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) [bundleFile:1.0.9]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) [bundleFile:1.0.9]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) [bundleFile:1.0.9]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220) [bundleFile:1.0.9]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [bundleFile:3.1.0]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
Any idea what changed, or what is wrong with the coding? Something with the “java data things”?
Any suggestions appreciated.
Best regards
Stefan
PS:
The rule is executed!
I have to correct myself:
Everytime a rule is executed manually with every rule (DSL) the error is thrown. Even with this script:
logInfo("TEST","thats it")
One more hint:
When you enter the DSL rule via Settings->Rules a
2021-03-10 09:29:33.990 [INFO ] [openhab.event.RuleUpdatedEvent      ] - Rule '4ca39db864' has been updated.
appears.
When you then start the rule manually, the error(s) appear. When you do a 2nd manual start of the rule, no error pops up…
but in the logifles the error message appears sometimes for background starts depending on the “WHEN” setting.
I’ve not seen this error reported. I recommend filing an issue on openhab-core for more assistance. I’ve never seen that error and cannot guess as to it’s cause.
I also do have with existing rules (no error) now with 3.1.0.M2 the same error as above.
Rules work but it is annoying as the openhab.log file gets flooded during development with this…
Any Hints?
Extra information, it seems that I get per rule definition in a rules file the error (3 rules = 3 errors). For me the first error:
2021-03-14 10:40:06.551 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘solar.rules’
2021-03-14 10:40:06.699 [INFO ] [ext.common.types.util.TypeReferences] - Couldn’t find JvmType for name ‘org.openhab.core.model.script.actions.Semantics’ in context org.eclipse.xtext.xbase.resource.BatchLinkableResource@1ad432b uri=‘tmp_solar.rules’
at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getStaticImportClasses(ImplicitlyImportedFeatures.java:68) [bundleFile:?]
at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.newSession(XbaseBatchScopeProvider.java:120) [bundleFile:?]
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:61) [bundleFile:?]
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:42) [bundleFile:?]
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getEObject(BatchLinkableResource.java:118) [bundleFile:?]
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [bundleFile:?]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:209) [bundleFile:?]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:269) [bundleFile:?]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477) [bundleFile:?]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getFeature(XAbstractFeatureCallImplCustom.java:49) [bundleFile:?]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.ensureFeatureLinked(XAbstractFeatureCallImplCustom.java:136) [bundleFile:?]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getImplicitReceiver(XAbstractFeatureCallImplCustom.java:107) [bundleFile:?]
at org.eclipse.xtext.xbase.util.XbaseUsageCrossReferencer$1.getEObjectChildren(XbaseUsageCrossReferencer.java:50) [bundleFile:?]
at org.eclipse.emf.ecore.util.EcoreUtil$ContentTreeIterator.getChildren(EcoreUtil.java:1455) [bundleFile:?]
at org.eclipse.emf.common.util.AbstractTreeIterator.next(AbstractTreeIterator.java:138) [bundleFile:?]
at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossReference(EcoreUtil.java:1774) [bundleFile:?]
at org.eclipse.emf.ecore.util.EcoreUtil$UsageCrossReferencer.findUsage(EcoreUtil.java:2673) [bundleFile:?]
at org.eclipse.xtext.xbase.util.XbaseUsageCrossReferencer.find(XbaseUsageCrossReferencer.java:35) [bundleFile:?]
at org.eclipse.xtext.xbase.validation.XbaseValidator.isLocallyUsed(XbaseValidator.java:1360) [bundleFile:?]
at org.eclipse.xtext.xbase.validation.XbaseValidator.checkLocalUsageOfDeclared(XbaseValidator.java:1112) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor71.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:129) [bundleFile:?]
at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:337) [bundleFile:?]
at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:72) [bundleFile:?]
at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:151) [bundleFile:?]
at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:257) [bundleFile:?]
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:244) [bundleFile:?]
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:201) [bundleFile:?]
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:131) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.lambda$2(ModelRepositoryImpl.java:280) [bundleFile:?]
at org.openhab.core.model.core.internal.SafeEMFImpl.call(SafeEMFImpl.java:30) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.validateModel(ModelRepositoryImpl.java:280) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:105) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) [bundleFile:?]
at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:322) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
That’s like
