I just installed OH 3.2 in a Debian 11 VM and installed the new JSScripting binding. I’ve created a file called testrule1.js in /etc/openhab/automation/js/ with the following contents:
'use strict';
// scriptExtension.importPreset("RuleSupport");
rules.JSRule({
name: "Change house mode",
description: "Change house mode",
triggers: [triggers.ItemStateChangeTrigger('HouseMode')],
execute: data => {
var logger = log(this.ruleUID);
var triggeringItemName = events.itemName;
logger.info("House mode changed to {}!", triggeringItemName);
The item HouseMode is a string and I’m changing it via the BasicUI between ‘DAY’ and ‘NIGHT’. I’d like to learn how to use the JS equivalent of triggeringItem since I’m planning to convert all my Jython rules to JS rules and some of those rules are triggered by group and need to know which item in the group triggered the rule.
The output in openhab.log for the above rule when item HouseMode is changed is:
2021-12-22 18:25:40.527 [DEBUG] [org.openhab.automation.script.rules ] - Extracted event payload [object Object]
2021-12-22 18:25:40.534 [ERROR] [org.openhab.automation.script.rules ] - Failed to execute rule Change-house-mode-38c11b40-e9c6-40d3-bb24-f5d0953b5e73: Refer
enceError: "events" is not defined: ReferenceError: "events" is not defined
at execute (testrule1.js:11)
at doExecute (webpack://openhab/./node_modules/openhab/rules/rules.js?:110)
2021-12-22 18:25:40.536 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'Change-house-mode-38c11b40-e9c6-40d3-bb24-f5d0953b5e73': Fai
l to execute action: 1
I’ve tried ‘event’ instead of ‘events’. I’ve also tried ‘input.event’ and the old ‘triggeringItem’ but always get an error.
I did a lot of searching and saw the following code in the documentation:
'use strict';
scriptExtension.importPreset("RuleSimple");
However, when I add that at the top of the file and save I see this in the log:
2021-12-22 18:28:31.199 [INFO ] [rulesupport.loader.ScriptFileWatcher] - Loading script '/etc/openhab/automation/js/testrule1.js'
2021-12-22 18:28:31.343 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "scriptExtension" is not defined
at <js>.:program(testrule1.js:3) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:379) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:400) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:249) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocable.eval(DelegatingScriptEngineWithInvocable.java:56) ~[?
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocable.eval(InvocationInterceptingScriptEngineWi
thInvocable.java:79) ~[?:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.loadScript(ScriptEngineManagerImpl.java:177) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.createAndLoad(ScriptFileWatcher.java:231) ~[?:?]
at org.openhab.automation.jsscripting.internal.fs.watch.JSScriptFileWatcher.createAndLoad(JSScriptFileWatcher.java:57) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importFile(ScriptFileWatcher.java:211) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.lambda$2(ScriptFileWatcher.java:203) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importFileWhenReady(ScriptFileWatcher.java:201) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.processWatchEvent(ScriptFileWatcher.java:178) ~[?:?]
at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2021-12-22 18:28:31.345 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/js/testrule1.js': or
Could someone post the entire contents of a simple JS rule file please? In all the threads I’ve seen in my searching only the parts of the rule that people are working on are quoted and I’ve not seen an entire rule file yet. At least, I don’t think I have!
