Thanks for the reply. I took all the way from Milestone1 to Milestone3. I realized that with M2 there started a single switch to make problems, and that this was “faulty parameter” based. But its hard to find a solution when the debug log does not show any errors at all. So i ignored this wall plug switch. But now its different and no switch does turn off/on annymore.
In my case the zwave things are added by the binding automatically (scanning). But i do link items manually via items files.
Here is the log of a wall plug that should go ON OFF via GUI but does not react in reality.
Is there a more bullet proof way to fix this than to look into all devices config. Debug log does not help me at all from what i see and going into the GUI things parameters i do not see anything that would help to change. Even if it means to reconfigure everything. better than to spend others time too heavy.
2022-04-04 10:05:41.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00
2022-04-04 10:05:41.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-04-04 10:05:41.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:PING)
2022-04-04 10:05:41.569 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-04-04 10:05:41.570 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_METER
2022-04-04 10:05:41.571 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-04-04 10:05:41.572 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=47.7
2022-04-04 10:05:41.573 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-04-04 10:05:41.573 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=47.7
2022-04-04 10:05:41.575 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:9b5794294d:node5:meter_watts to 47.7 [DecimalType]
2022-04-04 10:05:41.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-04-04 10:05:41.578 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a77a13.
2022-04-04 10:05:41.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.580 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.580 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-04-04 10:05:41.581 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-04-04 10:05:41.659 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 07 0E 32 02 21 34 00 00 00 0B 00 00 00 00 00 00 C8
2022-04-04 10:05:41.661 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=0, payload=00 07 0E 32 02 21 34 00 00 00 0B 00 00 00 00 00 00
2022-04-04 10:05:41.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=0, payload=00 07 0E 32 02 21 34 00 00 00 0B 00 00 00 00 00 00
2022-04-04 10:05:41.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-04-04 10:05:41.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Application Command Request (ALIVE:PING)
2022-04-04 10:05:41.665 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-04-04 10:05:41.666 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: SECURITY NOT required on COMMAND_CLASS_METER
2022-04-04 10:05:41.667 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 7: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-04-04 10:05:41.667 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00 1D
2022-04-04 10:05:41.668 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 7: Meter: Type=Electric(1), Scale=W(2), Value=1.1
2022-04-04 10:05:41.668 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-04-04 10:05:41.669 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=1.1
2022-04-04 10:05:41.670 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Updating channel state zwave:device:9b5794294d:node7:meter_watts to 1.1 [DecimalType]
2022-04-04 10:05:41.670 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00
2022-04-04 10:05:41.672 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Commands processed 1.
2022-04-04 10:05:41.673 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@23b526.
2022-04-04 10:05:41.673 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00
2022-04-04 10:05:41.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-04-04 10:05:41.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:PING)
2022-04-04 10:05:41.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-04-04 10:05:41.678 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_METER
2022-04-04 10:05:41.678 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-04-04 10:05:41.679 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=47.7
2022-04-04 10:05:41.680 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-04-04 10:05:41.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=47.7
2022-04-04 10:05:41.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:9b5794294d:node5:meter_watts to 47.7 [DecimalType]
2022-04-04 10:05:41.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-04-04 10:05:41.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d582d6.
2022-04-04 10:05:41.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.685 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.686 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-04-04 10:05:41.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-04-04 10:05:41.695 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00 1D
2022-04-04 10:05:41.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00
2022-04-04 10:05:41.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00
2022-04-04 10:05:41.699 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-04-04 10:05:41.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:PING)
2022-04-04 10:05:41.701 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-04-04 10:05:41.701 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_METER
2022-04-04 10:05:41.702 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-04-04 10:05:41.703 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=47.7
2022-04-04 10:05:41.703 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
2022-04-04 10:05:41.704 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=47.7
2022-04-04 10:05:41.705 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:9b5794294d:node5:meter_watts to 47.7 [DecimalType]
2022-04-04 10:05:41.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2022-04-04 10:05:41.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f8fd9d.
2022-04-04 10:05:41.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2022-04-04 10:05:41.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2022-04-04 10:05:41.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2022-04-04 10:05:41.724 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 10 07 0E 32 02 21 34 00 00 00 0E 00 00 00 00 00 00 DD
2022-04-04 10:05:41.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=16, payload=10 07 0E 32 02 21 34 00 00 00 0E 00 00 00 00 00 00
2022-04-04 10:05:41.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=7, callback=16, payload=10 07 0E 32 02 21 34 00 00 00 0E 00 00 00 00 00 00
2022-04-04 10:05:41.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2022-04-04 10:05:41.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Application Command Request (ALIVE:PING)
2022-04-04 10:05:41.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Incoming command class COMMAND_CLASS_METER, endpoint 0
2022-04-04 10:05:41.730 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: SECURITY NOT required on COMMAND_CLASS_METER
2022-04-04 10:05:41.731 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 7: Received COMMAND_CLASS_METER V3 METER_REPORT
2022-04-04 10:05:41.732 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 7: Meter: Type=Electric(1), Scale=W(2), Value=1.4
2022-04-04 10:05:41.733 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 34 00 00 01 DD 00 00 00 00 00 00 1D
