OH 3.4.2 Stable: Zwave Controller does not come online after upgrade from OH 3.3
I created another docker instance with openHAB 3.4.2 beside my running openHAB 3.3.0 M5. Both are running on a Synology Disk with enough CPU power and RAM. For Zwave I use a Aoetec Z-Stick Gen 5.
The behaviour with 3.3.0 M5: Everything is fine. After booting the stick comes up and network goes live.
The problem with 3.4: It seems that the controller does not know that it is the controller.
First it changes from UNINITIALIZED to HANDLER MISSING.
[ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:23fdd2f523' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
[ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:23fdd2f523' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
Then to OFFLINE because the bridge (itself) is offline
[ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:23fdd2f523' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to INITIALIZING
[ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:23fdd2f523' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
The log from zwave.log (DEBUG level) shows that (but I do not understand it):
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : BundleComponentActivator : ComponentHolder created.
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : BundleComponentActivator : ComponentHolder created.
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Dependency Manager created ConfigDescriptionRegistryinterface=org.openhab.core.config.core.ConfigDescriptionRegistry, filter=null, policy=static, cardinality=1..1, bind=setConfigDescriptionRegistry, unbind=unsetConfigDescriptionRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Dependency Manager created ThingRegistryinterface=org.openhab.core.thing.ThingRegistry, filter=null, policy=static, cardinality=1..1, bind=setThingRegistry, unbind=unsetThingRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Dependency Manager created ThingTypeRegistryinterface=org.openhab.core.thing.type.ThingTypeRegistry, filter=null, policy=static, cardinality=1..1, bind=setThingTypeRegistry, unbind=unsetThingTypeRegistry, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Component created: DS=DS13, implementation=org.openhab.binding.zwave.internal.ZWaveConfigProvider, immediate=true, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.zwave.internal.ZWaveConfigProvider]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Component Services: scope=singleton, services=[org.openhab.core.config.core.ConfigDescriptionProvider, org.openhab.core.config.core.ConfigOptionProvider]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Component Properties: {}
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Querying state disabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider] : Component can not be activated since it is in state disabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Updating target filters
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : No change in target property for dependency ConfigDescriptionRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] :  No existing service listener to unregister for dependency ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Setting target property for dependency ConfigDescriptionRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : New service tracker for ConfigDescriptionRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.config.core.ConfigDescriptionRegistry), initialReferenceFilter (objectClass=org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ConfigDescriptionRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic added {org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=234, service.bundleid=161, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=117} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ConfigDescriptionRegistry tracking 1 SingleStatic added {org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=234, service.bundleid=161, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=117} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ConfigDescriptionRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : registering service listener for dependency ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : No change in target property for dependency ThingRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] :  No existing service listener to unregister for dependency ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Setting target property for dependency ThingRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : New service tracker for ThingRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.ThingRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingRegistry tracking 2 SingleStatic added {org.openhab.core.thing.ThingRegistry}={service.id=372, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=254} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingRegistry tracking 2 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingRegistry tracking 2 SingleStatic added {org.openhab.core.thing.ThingRegistry}={service.id=372, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=254} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : registering service listener for dependency ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : No change in target property for dependency ThingTypeRegistry: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] :  No existing service listener to unregister for dependency ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Setting target property for dependency ThingTypeRegistry to null
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : New service tracker for ThingTypeRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.type.ThingTypeRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingTypeRegistry tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingTypeRegistry tracking 3 SingleStatic added {org.openhab.core.thing.type.ThingTypeRegistry}={service.id=530, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=269} (enter)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingTypeRegistry tracking 3 SingleStatic active: false trackerOpened: false optional: false
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingTypeRegistry tracking 3 SingleStatic added {org.openhab.core.thing.type.ThingTypeRegistry}={service.id=530, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=269} (exit)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : dm ThingTypeRegistry tracker opened
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : registering service listener for dependency ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Changed state from disabled to unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Component enabled
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : ActivateInternal
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Querying state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Activating component from state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Changed state from unsatisfiedReference to satisfied
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : registration change queue [registered]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Checking constructor public org.openhab.binding.zwave.internal.ZWaveConfigProvider()
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Found constructor with 0 arguments : public org.openhab.binding.zwave.internal.ZWaveConfigProvider()
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getting bind: setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Locating method setConfigDescriptionRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getReferenceClass: Looking for interface class org.openhab.core.config.core.ConfigDescriptionRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getParameterClass: Found class org.openhab.core.config.core.ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.config.core.ConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry(org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setConfigDescriptionRegistry(org.openhab.core.config.core.ConfigDescriptionRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getting bind: setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Locating method setThingRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getReferenceClass: Looking for interface class org.openhab.core.thing.ThingRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getParameterClass: Found class org.openhab.core.thing.ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.thing.ThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry(org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingRegistry(org.openhab.core.thing.ThingRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getting bind: setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Locating method setThingTypeRegistry in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getReferenceClass: Looking for interface class org.openhab.core.thing.type.ThingTypeRegistry through loader of org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getParameterClass: Found class org.openhab.core.thing.type.ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.thing.type.ThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry(org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveConfigProvider.setThingTypeRegistry(org.openhab.core.thing.type.ThingTypeRegistry)
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : This thread collected dependencies
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getService (single component manager) dependencies collected.
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Querying state satisfied
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : For dependency ConfigDescriptionRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.config.core.ConfigDescriptionRegistry}={service.id=234, service.bundleid=161, service.scope=bundle, component.name=org.openhab.core.config.core.ConfigDescriptionRegistry, component.id=117}] service: [org.openhab.core.config.core.ConfigDescriptionRegistry@17f31c27]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : For dependency ThingRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.ThingRegistry}={service.id=372, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingRegistryImpl, component.id=254}] service: [org.openhab.core.thing.internal.ThingRegistryImpl@6d1b8742]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : For dependency ThingTypeRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.type.ThingTypeRegistry}={service.id=530, service.bundleid=212, service.scope=bundle, component.name=org.openhab.core.thing.type.ThingTypeRegistry, component.id=269}] service: [org.openhab.core.thing.type.ThingTypeRegistry@153896d0]]]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoking bind: setConfigDescriptionRegistry: parameters [org.openhab.core.config.core.ConfigDescriptionRegistry]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoked bind: setConfigDescriptionRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoking bind: setThingRegistry: parameters [org.openhab.core.thing.internal.ThingRegistryImpl]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoked bind: setThingRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoking bind: setThingTypeRegistry: parameters [org.openhab.core.thing.type.ThingTypeRegistry]
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : invoked bind: setThingTypeRegistry
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : getting activate: activate
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Locating method activate in class org.openhab.binding.zwave.internal.ZWaveConfigProvider
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method org.openhab.binding.zwave.internal.ZWaveConfigProvider.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Locating method activate in class java.lang.Object
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : activate method [activate] not found, ignoring
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Set implementation object for component
[DEBUG] [g.zwave.internal.ZWaveConfigProvider] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveConfigProvider(344)] : Changed state from satisfied to active
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Dependency Manager created SerialPortManagerinterface=org.openhab.core.io.transport.serial.SerialPortManager, filter=null, policy=static, cardinality=1..1, bind=setSerialPortManager, unbind=unsetSerialPortManager, updated=null, field=null, field-option=null, collection-type=null, parameter=null
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Component created: DS=DS13, implementation=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.zwave.internal.ZWaveHandlerFactory]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.binding.ThingHandlerFactory]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Component Properties: {}
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Querying state disabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory] : Component can not be activated since it is in state disabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Updating target filters
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : No change in target property for dependency SerialPortManager: currently registered: false
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] :  No existing service listener to unregister for dependency SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Setting target property for dependency SerialPortManager to null
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : New service tracker for SerialPortManager, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.io.transport.serial.SerialPortManager), initialReferenceFilter (objectClass=org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : dm SerialPortManager tracker reset (closed)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : dm SerialPortManager tracker opened
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : registering service listener for dependency SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Changed state from disabled to unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Component enabled
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : ActivateInternal
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Querying state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Activating component from state unsatisfiedReference
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Dependency not satisfied: SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Not all dependencies satisfied, cannot activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : dm SerialPortManager tracking 1 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=719, service.bundleid=289, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=352} (enter)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Changed state from unsatisfiedReference to satisfied
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : registration change queue [registered]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Checking constructor public org.openhab.binding.zwave.internal.ZWaveHandlerFactory()
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Found constructor with 0 arguments : public org.openhab.binding.zwave.internal.ZWaveHandlerFactory()
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : getting bind: setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Locating method setSerialPortManager in class org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : doFindMethod: Looking for method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager([interface org.osgi.framework.ServiceReference]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager([interface org.osgi.service.component.ComponentServiceObjects]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : getReferenceClass: Looking for interface class org.openhab.core.io.transport.serial.SerialPortManager through loader of org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : getParameterClass: Found class org.openhab.core.io.transport.serial.SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : doFindMethod: No method taking ServiceReference found, checking method taking org.openhab.core.io.transport.serial.SerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : doFindMethod: Found Method protected void org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager(org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Found bind method: protected void org.openhab.binding.zwave.internal.ZWaveHandlerFactory.setSerialPortManager(org.openhab.core.io.transport.serial.SerialPortManager)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : This thread collected dependencies
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : getService (single component manager) dependencies collected.
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Querying state satisfied
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : For dependency SerialPortManager, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.io.transport.serial.SerialPortManager}={service.id=719, service.bundleid=289, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=352}] service: [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl@15710ff8]]]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : invoking bind: setSerialPortManager: parameters [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : invoked bind: setSerialPortManager
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : getting activate: activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Locating method activate in class org.openhab.binding.zwave.internal.ZWaveHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Declared Method org.openhab.binding.zwave.internal.ZWaveHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : invoked activate: activate
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Set implementation object for component
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : Changed state from satisfied to active
[DEBUG] [g.zwave.internal.ZWaveHandlerFactory] - bundle org.openhab.binding.zwave:3.4.2 (282)[org.openhab.binding.zwave.internal.ZWaveHandlerFactory(345)] : dm SerialPortManager tracking 1 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=719, service.bundleid=289, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=352} (exit)
[DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:23fcd2f523 with scan time of 60
[DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:23fcd2f523
[INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
[DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
[DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:23fcd2f523.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node145.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node58.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node141.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node146.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node143.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node132.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node57.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node142.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node140.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node55.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node130.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node51.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node7.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node2.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node6.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node147.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node3.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node67.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node50.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node45.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node8.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node65.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node61.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node62.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node39.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node44.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node36.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node37.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node35.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node42.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node31.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node32.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node30.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node135.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node136.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node40.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node15.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node18.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node137.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node12.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node16.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node28.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node99.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node138.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node11.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node91.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node27.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node10.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node92.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node29.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node95.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node20.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node110.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node21.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node23.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node79.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node77.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node73.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node87.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node85.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node119.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node106.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node102.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node84.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node105.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node82.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node118.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node114.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node123.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node129.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node104.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node113.
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:23fcd2f523:node128.
Please have in mind, that when I power down 3.4 and power up 3.3 everything is fine. Also, I started 3.4 directly after a fresh reboot of the Synology.
I also tried to restart openHAB docker container and also to restart the zwave binding several times from terminal with
/openhab/runtime/bin/client bundle:restart org.openhab.binding.zwave
Also a deletion and recreation of the controller thing had no success.
And I added
-Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0 to EXTRA_JAVA_OPTs
I used a few hours to find the error but I wasn’t successful.
Does anyone have some hints for me? Serial ports? Something outside openHAB? A library like librxtx-java missing in the Docker images?
Thanks in advance!
HFM
P.S.: In openHAB 4.0.0 Snapshot the problem exists, too.
P.S.S.: The old image is backupped and can be used, but I would have to stay there if I cannot upate…
Okay, I tried 3.3.0-RC1 and 3.3.0-M6 both seem not to work. Does anyone know if there were changes between M5 and M6 which could lead to a block of Zwave?
For the people who have the same problems with Synology, Docker and a Zwave Stick (maybe also an Zigbee Stick):
After a little bit more of testing, I found the problem. It is the GUI of the Docker in Synology. You NEED to pass the device with --device=/dev/ttyACM0, but you do not have the possibility to do it in the GUI. When you did it once, everything is good. I think I did it the last time via console and forgot about it.
Special hint: Use Portainer on Synonlogy instead of the native Docker app. There you can add the device.
The good thing: I already wanted to try portainer. Now I have it. :slight_smile:
Bye
HFM
