openHAB version: 3.1.0.M3
Hi All
I have been playing with a Custom Widget, and would now like to add some audio to indicate errors etc…
So I looked at the current Multimedia Docs for ideas etc.
So I have set the default Audio Sync in Settings to We Audio:
I did see that. And when I went to look for it again could not find it… So was not 100% sure of the exact wording. Found it again now with your help:
Web Audio
Convenient, if sounds should not be played on the server, but on the client:
This sink sends the audio stream through HTTP to web clients, which then cause
it to be played back by the browser. Obviously, the browser needs to be opened
and have a compatible openHAB UI running.
Currently, this feature is supported by UI and HABPanel.
I guess I was hoping that this was a documentation issue, but I guess not. I was also not 100% about “UI”. I know of Main UI, Basic UI, Paper UI. But don’t recall seeing anything about “UI”.
