Hi there,
i would like to control the week profile of a HmIP-BROLL rollershutter.
It is only needed in one room where i´m using the internal week profiles to open and close in multiple steps over time.
The rollershutter is programmed to do the following
sunrise = 5%
sunrise + 30 minutes = 10%
sunrise + 60 minutes = 15%
sunrise + 90 minutes = 20%
sunrise + 120 minutes = 100%
I can change the week profile for channel 4 from automatic to manual inside the ccu3.
Now i want to change this from an openHAB rule.
What is my goal?
I want to change the week profile to manual when someone used the UP
or DOWN
buttons of the rollershutter to manually move the blinds.
So if someone opens the blinds before or between the automatic profiles they should stay open.
Currently they get moved to the position of the week profile even if someone changed them manually.
I know that i could do this inside of the ccu3 but that would limit me to homematic specific triggers.
I also want to use triggers from other vendors that are connected to my oH3 instance.
homemmatic items:
Number hmRolladeTCLn {channel="homematic:HmIP-BROLL:ccu3:XXX:7#WEEK_PROGRAM_TARGET_CHANNEL_LOCKS"}
String hmRolladeCombined {channel="homematic:HmIP-BROLL:ccu3:XXX:7#COMBINED_PARAMETER"}
String hmRolladeTCLs {channel="homematic:HmIP-BROLL:ccu3:XXX:7#WEEK_PROGRAM_TARGET_CHANNEL_LOCK"}
Number hmRolladeCL {channel="homematic:HmIP-BROLL:ccu3:XXX:7#WEEK_PROGRAM_CHANNEL_LOCKS"}
I already tried changing the week profile in the ccu3 and see if one of the items changes…
The only item that changes is hmRolladeCL
from 0
to 1
for changing from automatic to manual.
When using a rule to do this, it doesn´t change anything on the ccu3 side and the week profile will stay unchanged.
Has someone a solution for this?
- Platform information:
- Hardware: Raspberry Pi 4 Model B Rev 1.1
- OS: Raspbian GNU/Linux 10 (buster) (openhabian image)
- Java Runtime Environment:
- openjdk version “11.0.11” 2021-04-20 LTS
- OpenJDK Runtime Environment Zulu11.48+21-CA (build 11.0.11+9-LTS)
- OpenJDK Client VM Zulu11.48+21-CA (build 11.0.11+9-LTS, mixed mode)
- openHAB version: 3.0.2 - Release Build
- CCU 3
