I have this two serial ports onboard :
but under OH4.0.4 I’m not able uder ebus.bridge select this serial ports. Sw is still asking for USB serial device :
HANDLER_CONFIGURATION_PENDING
{serialPort=The value of /dev/ttyAML1 does not match the enabled options parameter. Allowed options are: [ParameterOption [value=“/dev/ttyUSB1”, label=“/dev/ttyUSB1”], ParameterOption [value=“/dev/ttyUSB0”, label=“/dev/ttyUSB0”], ParameterOption [value =“/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0”, label=“/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0”], ParameterOption [value=“/dev/ serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0”, label=“/dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0”]]}
I also tried use
ln /dev/ttyAML1 /dev/ttyS1
But also not accepted
Don’t know why, but it must be a SW bug
