I am experiencing a strange issue for a few days now.
Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors;
JdbcSQLException: Error in SQL query!!!; yank-default - Connection is not available, request timed out after 30000ms.
My OpenHAB instance uses MariaDB for persistence through the jdbc Addon. A few days ago, the host system of the MariaDB was down for about a day and since it came back on I regularly get weird errors and OpenHAB even stops persisting data due to them.
All out of a sudden, OpenHAB cannot persist data any longer - jdbc says there have been connection errors and therfore MariaDB does not accept new connections from OpenHAB any longer. Some queries run unreasonably long while I do not see too much of a load on the database.
In a nutshell it looks like this
Logs
2024-10-23 09:32:42.407 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic esphome/display/camera
2024-10-23 09:32:42.417 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic esphome/display/doorbell
2024-10-23 09:32:42.425 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic esphome/display/washingmachine
2024-10-23 09:32:42.432 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic esphome/display/dishwasher
2024-10-23 09:32:52.325 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-10-23 09:34:16.463 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-10-23 09:34:22.754 [WARN ] [iadb.jdbc.message.server.ErrorPacket] - Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'
2024-10-23 09:34:22.868 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-10-23 09:34:23.012 [WARN ] [iadb.jdbc.message.server.ErrorPacket] - Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'
2024-10-23 09:34:23.391 [WARN ] [iadb.jdbc.message.server.ErrorPacket] - Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'
2024-10-23 09:34:23.958 [WARN ] [iadb.jdbc.message.server.ErrorPacket] - Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'
2024-10-23 09:34:24.805 [WARN ] [iadb.jdbc.message.server.ErrorPacket] - Error: 1129-HY000: Host 'openhabian' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'
There is also hints about the query running to long such as
Logs
2024-10-23 10:51:00.255 [WARN ] [jdbc.internal.JdbcPersistenceService] - JDBC::store: Unable to store item
org.openhab.persistence.jdbc.internal.exceptions.JdbcSQLException: Error in SQL query!!!; yank-default - Connection is not available, request timed out after 30000ms.; Pool Name= yank-default; SQL= INSERT INTO item0023 (time, value) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ?
at org.openhab.persistence.jdbc.internal.db.JdbcBaseDAO.doStoreItemValue(JdbcBaseDAO.java:441) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.storeItemValue(JdbcMapper.java:220) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.internalStore(JdbcPersistenceService.java:174) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.lambda$1(JdbcPersistenceService.java:146) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
A temporary fix is to just do as I am told in the error message and tell the database to “flush hosts” which allows openhab to connect again as far as I understand.
This only helps for a while though.
I already tried
- restart OpenHAB
- reboot MariaDB host system
- restarted MariaDB service
- rebooted OpenHABian which I run on a Raspberry Pi
- checked network connection between OpenHABian and MariaDB - don’t see relevant delays
- The
max_connections
at the MariaDB is set to the default value of 151 and I do not think it has changed since the issue came up. Increased to 400 anyway - http://:8080/settings/addons/persistence-jdbc-mariadb increased the maximum pool size to
500
Does anyone have an idea how to solve this or maybe guide me through debugging the issue?
