I’m getting this is logs and I can’t seem to fix it:
2024-02-16 16:26:11.155 [WARN ] [nternal.profiles.SystemOffsetProfile] - Received a QuantityType state '7371786 Wh' with unit, but the offset is defined as a plain number without unit (1), please consider adding a unit to the profile offset.
2024-02-16 16:26:11.158 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Energy_EV_Acc' updated to 7371.787 kWh
as you can see the item underneath is the target, it has a unit of measure set and it is converted correctly.
any ideas?
