OH 4.3 Log Viewer - Access Recent Logs
Previously with Frontail I believe it showed a certain number of recent logs when it was opened. With the new log viewer, it starts with a blank screen. Often I’m checking the logs for something that just happened. Is there a way to have it show the last X number of log entries when opened?
Not yet but I think there is a PR open to add that to the log viewer. It should definitely be available in OH 5 unless there is some technical reason it cannot be done at all. The MainUI Log Viewer gets a feed of logs to display straight from OH. Frontail reads from a file. So it’s not as simple as just “look further back in the file”.
Ah, that makes sense and I know how to find the older logs so I guess that will work.
