- Platform information:
- Hardware: Synology Diskstation 720+ / INTEL Celeron J4125 / 10GB
- OS: DSM 7.2 / Container Manager 20.10.23-1437 (Docker)
- openHAB version: 4.1.2
- Issue of the topic: Analyzer in OH works super slow.
Hi guys!
Just recently my OH Analyzer decided to create/show graphs super slow. It’s not related to an update (or I’m not aware of it). The update to 4.1.2 did not change nothing.
Only if I use my MacBook with Opera browser (Safari has the same issue) the Analyzer creates the diagram right away.
Please see the attached video.
When I press the ‘Controls’ it starts creating the graph…
- If logs where generated please post these here using code fences:
events.log right after reboot:
2024-04-24 05:16:15.445 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da7c2f7c' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:16:15.962 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_1_1' changed from UNKNOWN to ONLINE
2024-04-24 05:16:15.971 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:bridge:MEQ1490729' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2024-04-24 05:16:16.187 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da35c494' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:16:16.205 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vicare:bridge:b818d8e656' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2024-04-24 05:16:16.219 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vicare:bridge:b818d8e656' changed from INITIALIZING to UNKNOWN
2024-04-24 05:16:16.228 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vicare:heating:b818d8e656:dae2f889-8c19-3aa4-9dea-42dcdaab27d4' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:16.249 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da7c2f7c' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to ONLINE
2024-04-24 05:16:16.252 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe14604' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2024-04-24 05:16:16.252 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IRHeizungBad_PowerState' changed from NULL to ON
2024-04-24 05:16:16.253 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'OGHeating' changed from NULL to ON through IRHeizungBad_PowerState
2024-04-24 05:16:16.254 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from NULL to 864.2 W
2024-04-24 05:16:16.254 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from NULL to 789.469 kWh
2024-04-24 05:16:16.559 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da35c494' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket error
2024-04-24 05:16:16.572 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vicare:bridge:b818d8e656' changed from UNKNOWN to ONLINE
2024-04-24 05:16:16.877 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_EnergieStatus' changed from NULL to ON
2024-04-24 05:16:16.877 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'EGLicht' changed from NULL to ON through WohnzimmerStehlampe_EnergieStatus
2024-04-24 05:16:16.878 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'WLicht' changed from NULL to ON through WohnzimmerStehlampe_EnergieStatus
2024-04-24 05:16:16.886 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from NULL to 11.91 W
2024-04-24 05:16:17.033 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vicare:heating:b818d8e656:dae2f889-8c19-3aa4-9dea-42dcdaab27d4' changed from INITIALIZING to ONLINE
2024-04-24 05:16:17.114 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FridaThermostat_OperatingVoltage' changed from NULL to 2.5 V
2024-04-24 05:16:17.116 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'HomeBatteries' changed from 2.6 V to 2.5 V through FridaThermostat_OperatingVoltage
2024-04-24 05:16:17.839 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:FRITZ_DECT_210:192_168_1_1:116570544335' changed from UNKNOWN to ONLINE
2024-04-24 05:16:17.842 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from NULL to 3343.877 kWh
2024-04-24 05:16:17.846 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 23.45 W to 26.99 W
2024-04-24 05:16:17.850 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from NULL to 232.766 V
2024-04-24 05:16:17.853 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_ActualTemperatur' changed from NULL to 14.5 °C
2024-04-24 05:16:17.855 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:FRITZ_DECT_210:192_168_1_1:116570544437' changed from UNKNOWN to ONLINE
2024-04-24 05:16:17.859 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from NULL to 2096.513 kWh
2024-04-24 05:16:17.862 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from NULL to 34.04 W
2024-04-24 05:16:17.864 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from NULL to 229.815 V
2024-04-24 05:16:18.254 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe14604' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:16:18.948 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 864.2 W to 863.4 W
2024-04-24 05:16:19.202 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.469 kWh to 789.47 kWh
2024-04-24 05:16:19.206 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_OperatingVoltage' changed from NULL to 2.7 V
2024-04-24 05:16:20.069 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.91 W to 11.86 W
2024-04-24 05:16:21.138 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 11.94 W
2024-04-24 05:16:21.341 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe14604' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to ONLINE
2024-04-24 05:16:21.344 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LichtEsszimmer_PowerStatus' changed from NULL to ON
2024-04-24 05:16:21.354 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from NULL to 6.7 W
2024-04-24 05:16:23.139 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FridaThermostat_SetPointTemperature' changed from NULL to 5 °C
2024-04-24 05:16:23.403 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.94 W to 12.08 W
2024-04-24 05:16:23.589 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.7 W to 6.6 W
2024-04-24 05:16:26.390 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Viessmann_HK_Heizung_Zieleinstellung' changed from NULL to 22 °C
2024-04-24 05:16:26.391 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ViessmannHeizkreisFussbodenheizung_SetPointTemperature' changed from NULL to 19 °C
2024-04-24 05:16:26.394 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ViessmannWarmwasser_Temperature' changed from NULL to 52.5 °C
2024-04-24 05:16:26.399 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ViessmannAussentemperatursensor_ActualTemperature' changed from NULL to 4.3 °C
2024-04-24 05:16:26.443 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FridaThermostat_BoostMode' changed from NULL to OFF
2024-04-24 05:16:26.449 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.08 W to 11.91 W
2024-04-24 05:16:27.042 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FridaThermostat_Level' changed from NULL to 0.0
2024-04-24 05:16:27.713 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'ODLicht' changed from NULL to ON through Aussenbeleuchtung_State
2024-04-24 05:16:27.714 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Aussenbeleuchtung_State' changed from NULL to OFF
2024-04-24 05:16:28.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ThermostatFrida_ActualTemperature' changed from NULL to 16.9 °C
2024-04-24 05:16:29.500 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.91 W to 11.94 W
2024-04-24 05:16:30.546 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1-DR:MEQ1490729:MEQ1560224' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:30.807 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_Motion' changed from NULL to OFF
2024-04-24 05:16:31.376 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerSTH_Humidity' changed from NULL to 43.0
2024-04-24 05:16:31.897 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerSTH_SetPointTemperature' changed from NULL to 19 °C
2024-04-24 05:16:32.415 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'log_monthlyenergy' changed from NULL to 6221.654 kWh
2024-04-24 05:16:32.793 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1PBU-FM:MEQ1490729:NEQ0432141' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:32.799 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMI:MEQ1490729:0009178858A55C' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:32.822 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.94 W to 12.05 W
2024-04-24 05:16:32.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerSTH_ActualTemperature' changed from NULL to 20.4 °C
2024-04-24 05:16:33.309 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerGluhbirne_Helligkeit' changed from NULL to 0
2024-04-24 05:16:33.674 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HeizungLufter1_PowerState' changed from NULL to OFF
2024-04-24 05:16:34.216 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_Illumination' changed from NULL to 10.1
2024-04-24 05:16:34.781 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_monthlyenergy' changed from NULL to 218.724 kWh
2024-04-24 05:16:35.312 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroThermostat_Level' changed from NULL to 0.0
2024-04-24 05:16:35.783 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadSTH_SetPointTemperature' changed from NULL to 22 °C
2024-04-24 05:16:36.147 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.05 W to 11.87 W
2024-04-24 05:16:36.205 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LichtschalterCarport_State' changed from NULL to OFF
2024-04-24 05:16:36.205 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'ODLicht' changed from ON to OFF through LichtschalterCarport_State
2024-04-24 05:16:36.591 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'JuliusThermostat_BoostMode' changed from NULL to OFF
2024-04-24 05:16:36.822 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B49387' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:36.837 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B4939E' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:36.845 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5F29945064' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:37.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadSTH_Humidity' changed from NULL to 38.0
2024-04-24 05:16:37.341 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'JuliusThermostat_OperatingVoltage' changed from NULL to 2.4 V
2024-04-24 05:16:37.341 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'HomeBatteries' changed from 2.5 V to 2.4 V through JuliusThermostat_OperatingVoltage
2024-04-24 05:16:37.831 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_SignalStrength' changed from NULL to 4.0
2024-04-24 05:16:38.123 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Buro_Heizung_IR_Power_Consumption' changed from NULL to 0 W
2024-04-24 05:16:38.618 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ThermostatJulius_ActualTemperature' changed from NULL to 17.7 °C
2024-04-24 05:16:38.972 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerMotionSensor_SignalStrength' changed from NULL to 4.0
2024-04-24 05:16:39.082 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.87 W to 12.15 W
2024-04-24 05:16:39.327 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerGluhbirne_EnergieStatus' changed from NULL to OFF
2024-04-24 05:16:39.859 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroThermostat_OperatingVoltage' changed from NULL to 2.6 V
2024-04-24 05:16:40.375 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'log_dailyenergy' changed from NULL to 6440.372 kWh
2024-04-24 05:16:40.900 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerSTH_SetPointTemperature' changed from NULL to 17.5 °C
2024-04-24 05:16:41.171 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HeizungLufter2_PowerState' changed from NULL to OFF
2024-04-24 05:16:41.669 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'log_yearlyenergy' changed from NULL to 5710.828 kWh
2024-04-24 05:16:42.123 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KucheKaffeemaschine_EnergieStatus' changed from NULL to ON
2024-04-24 05:16:42.580 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_dailyenergy' changed from NULL to 0.013 kWh
2024-04-24 05:16:42.859 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61F99' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:42.864 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61FAA' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:42.868 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A5DE74' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:43.156 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerSTH_OperatingVoltage' changed from NULL to 2.6 V
2024-04-24 05:16:43.482 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from NULL to 2.4 W
2024-04-24 05:16:43.631 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Wohnzimmer_GB_WiZ_Color' changed from NULL to 0,0,0
2024-04-24 05:16:44.139 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadSTH_ActualTemperature' changed from NULL to 20.3 °C
2024-04-24 05:16:44.601 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadSTH_OperatingVoltage' changed from NULL to 2.6 V
2024-04-24 05:16:44.872 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMO-A:MEQ1490729:000BD788589B7B' changed from UNINITIALIZED (NOT_YET_READY) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2024-04-24 05:16:45.033 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroThermostat_BoostMode' changed from NULL to OFF
2024-04-24 05:16:45.183 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'eScooter_multiple_AutoAusTimer' changed from NULL to 10
2024-04-24 05:16:45.689 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'JuliusThermostat_SetPointTemperature' changed from NULL to 5 °C
2024-04-24 05:16:45.994 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:bridge:MEQ1490729' changed from INITIALIZING to ONLINE
2024-04-24 05:16:45.999 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1-DR:MEQ1490729:MEQ1560224' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.010 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1PBU-FM:MEQ1490729:NEQ0432141' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.017 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1-DR:MEQ1490729:MEQ1560224' changed from INITIALIZING to ONLINE
2024-04-24 05:16:46.031 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Sw1PBU-FM:MEQ1490729:NEQ0432141' changed from INITIALIZING to ONLINE
2024-04-24 05:16:46.037 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerMotionSensor_Motion' changed from NULL to OFF
2024-04-24 05:16:46.046 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61F99' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.051 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61FAA' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.065 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5F29945064' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.067 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B49387' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.073 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B4939E' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.199 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMI:MEQ1490729:0009178858A55C' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.201 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMO-A:MEQ1490729:000BD788589B7B' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.221 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A5DE74' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2024-04-24 05:16:46.365 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from NULL to 127.659 kWh
2024-04-24 05:16:46.810 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_yearlyenergy' changed from NULL to 729.55 kWh
2024-04-24 05:16:47.333 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerSTH_ActualTemperature' changed from NULL to 16.4 °C
2024-04-24 05:16:47.829 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_totalenergy' changed from NULL to 6440.385 kWh
2024-04-24 05:16:48.383 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61FAA' changed from INITIALIZING to ONLINE
2024-04-24 05:16:48.411 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A61F99' changed from INITIALIZING to ONLINE
2024-04-24 05:16:48.440 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMO-A:MEQ1490729:000BD788589B7B' changed from INITIALIZING to ONLINE
2024-04-24 05:16:48.463 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerSTH_Humidity' changed from NULL to 41.0
2024-04-24 05:16:48.468 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5F29945064' changed from INITIALIZING to ONLINE
2024-04-24 05:16:48.917 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'JuliusThermostat_Level' changed from NULL to 0.0
2024-04-24 05:16:49.153 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B49387' changed from INITIALIZING to ONLINE
2024-04-24 05:16:49.308 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ThermostatBuero_ActualTemperature' changed from NULL to 16.3 °C
2024-04-24 05:16:49.937 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerSTH_OperatingVoltage' changed from NULL to 2.7 V
2024-04-24 05:16:54.390 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_Illumination' changed from 10.1 to 13.30
2024-04-24 05:16:55.196 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-SMI:MEQ1490729:0009178858A55C' changed from INITIALIZING to ONLINE
2024-04-24 05:16:55.374 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-STH:MEQ1490729:000E5D89B4939E' changed from INITIALIZING to ONLINE
2024-04-24 05:16:55.615 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'eScooter_AutoAUS_Timer' received command 1800 s
2024-04-24 05:16:55.618 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'eScooter_AutoAUS_Timer' predicted to become 1800 s
2024-04-24 05:16:58.970 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.877 kWh to 3343.878 kWh
2024-04-24 05:16:58.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 26.99 W to 32.79 W
2024-04-24 05:16:58.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 232.766 V to 232.853 V
2024-04-24 05:16:59.258 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:MEQ1490729:000A1D89A5DE74' changed from INITIALIZING to ONLINE
2024-04-24 05:17:00.023 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.47 kWh to 789.48 kWh
2024-04-24 05:17:06.147 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.15 W to 11.9 W
2024-04-24 05:17:08.075 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.9 W to 12.03 W
2024-04-24 05:17:11.119 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.03 W to 11.76 W
2024-04-24 05:17:13.849 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.513 kWh to 2096.514 kWh
2024-04-24 05:17:13.850 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 34.04 W to 38.72 W
2024-04-24 05:17:13.853 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 229.815 V to 229.854 V
2024-04-24 05:17:19.321 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe763c8' changed from OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket connection closed abnormal to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:17:19.435 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe763c8' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket error
2024-04-24 05:17:21.568 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.76 W to 12.02 W
2024-04-24 05:17:23.171 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.02 W to 11.96 W
2024-04-24 05:17:25.321 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da35c494' changed from OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket error to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:17:25.450 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:d4d4da35c494' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to ONLINE
2024-04-24 05:17:25.581 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 863.4 W to 872.9 W
2024-04-24 05:17:25.582 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.48 kWh to 789.486 kWh
2024-04-24 05:17:26.213 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.96 W to 11.92 W
2024-04-24 05:17:36.569 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.92 W to 12.01 W
2024-04-24 05:17:38.260 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.01 W to 11.91 W
2024-04-24 05:17:48.648 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.91 W to 11.87 W
2024-04-24 05:17:50.305 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.87 W to 11.92 W
2024-04-24 05:18:00.022 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.486 kWh to 789.494 kWh
2024-04-24 05:18:03.653 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.92 W to 11.89 W
2024-04-24 05:18:05.353 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.89 W to 11.75 W
2024-04-24 05:18:18.653 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.75 W to 12.09 W
2024-04-24 05:18:19.499 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe763c8' changed from OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket error to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-04-24 05:18:19.738 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusplug:80646fe763c8' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to ONLINE
2024-04-24 05:18:19.742 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.659 kWh to 127.665 kWh
2024-04-24 05:18:20.402 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.09 W to 11.99 W
2024-04-24 05:18:25.692 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 872.9 W to 872.8 W
2024-04-24 05:18:25.694 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.494 kWh to 789.501 kWh
2024-04-24 05:18:26.459 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.99 W to 11.95 W
2024-04-24 05:18:33.652 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.95 W to 12.05 W
2024-04-24 05:18:34.394 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.05 W to 11.77 W
2024-04-24 05:18:35.949 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.4 W to 713.3 W
2024-04-24 05:18:36.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 713.3 W to 1177.5 W
2024-04-24 05:18:38.569 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.77 W to 11.8 W
2024-04-24 05:18:43.947 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1177.5 W to 1084.5 W
2024-04-24 05:18:44.144 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.878 kWh to 3343.88 kWh
2024-04-24 05:18:44.146 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 32.79 W to 35.76 W
2024-04-24 05:18:44.147 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 232.853 V to 233.26 V
2024-04-24 05:18:44.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1084.5 W to 3.1 W
2024-04-24 05:18:49.407 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.8 W to 12.12 W
2024-04-24 05:18:50.873 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.12 W to 11.86 W
2024-04-24 05:18:55.060 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerMotionSensor_Illumination' changed from 0.04 to 0.06
2024-04-24 05:19:00.020 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.501 kWh to 789.509 kWh
2024-04-24 05:19:00.031 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.665 kWh to 127.668 kWh
2024-04-24 05:19:04.398 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 11.92 W
2024-04-24 05:19:06.172 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.92 W to 12.13 W
2024-04-24 05:19:06.331 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 872.8 W to 0 W
2024-04-24 05:19:13.863 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.514 kWh to 2096.516 kWh
2024-04-24 05:19:13.864 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 38.72 W to 37.72 W
2024-04-24 05:19:13.864 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 229.854 V to 230.059 V
2024-04-24 05:19:19.403 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.13 W to 11.86 W
2024-04-24 05:19:19.963 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 3.1 W to 2.4 W
2024-04-24 05:19:21.467 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 12.01 W
2024-04-24 05:19:24.515 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.01 W to 11.93 W
2024-04-24 05:19:25.809 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.509 kWh to 789.51 kWh
2024-04-24 05:19:27.667 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.93 W to 11.94 W
2024-04-24 05:19:35.470 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.94 W to 11.93 W
2024-04-24 05:19:36.707 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.93 W to 11.81 W
2024-04-24 05:19:37.372 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroGB_Brightness' changed from 0 to 50
2024-04-24 05:19:37.373 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'BueroLicht' changed from OFF to ON through BuroGB_Brightness
2024-04-24 05:19:37.374 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'DGLicht' changed from OFF to ON through BuroGB_Brightness
2024-04-24 05:19:50.469 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.81 W to 12.06 W
2024-04-24 05:19:51.996 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.06 W to 11.92 W
2024-04-24 05:20:02.194 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_totalenergy' changed from 6440.385 kWh to 6440.396 kWh
2024-04-24 05:20:03.645 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_Illumination' changed from 13.30 to 18.30
2024-04-24 05:20:05.471 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.92 W to 11.88 W
2024-04-24 05:20:06.907 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.88 W to 11.78 W
2024-04-24 05:20:10.314 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.78 W to 11.93 W
2024-04-24 05:20:20.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.4 W to 2.6 W
2024-04-24 05:20:21.903 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.93 W to 11.96 W
2024-04-24 05:20:28.429 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.96 W to 11.87 W
2024-04-24 05:20:31.806 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.6 W to 6.7 W
2024-04-24 05:20:36.912 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.87 W to 12.01 W
2024-04-24 05:20:44.004 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.88 kWh to 3343.881 kWh
2024-04-24 05:20:44.005 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 35.76 W to 33.74 W
2024-04-24 05:20:44.006 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 233.26 V to 233.141 V
2024-04-24 05:20:51.913 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.01 W to 11.94 W
2024-04-24 05:20:52.328 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 0 W to 3.7 W
2024-04-24 05:20:53.339 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 3.7 W to 867.4 W
2024-04-24 05:20:53.944 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.6 W to 56.4 W
2024-04-24 05:20:54.967 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 56.4 W to 100.7 W
2024-04-24 05:20:55.570 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.94 W to 11.66 W
2024-04-24 05:21:00.017 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.51 kWh to 789.512 kWh
2024-04-24 05:21:00.754 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_dailyenergy' changed from 0.013 kWh to 0.024 kWh
2024-04-24 05:21:07.221 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.66 W to 11.96 W
2024-04-24 05:21:13.921 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.516 kWh to 2096.517 kWh
2024-04-24 05:21:13.921 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 37.72 W to 35.15 W
2024-04-24 05:21:13.922 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 230.059 V to 229.904 V
2024-04-24 05:21:20.169 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 100.7 W to 100 W
2024-04-24 05:21:22.219 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.96 W to 11.83 W
2024-04-24 05:21:26.019 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 867.4 W to 868.9 W
2024-04-24 05:21:26.020 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.512 kWh to 789.518 kWh
2024-04-24 05:21:29.370 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.83 W to 12.02 W
2024-04-24 05:21:31.917 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.7 W to 6.6 W
2024-04-24 05:21:37.220 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.02 W to 11.9 W
2024-04-24 05:21:40.522 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.9 W to 11.74 W
2024-04-24 05:21:42.968 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 100 W to 397.6 W
2024-04-24 05:21:43.941 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 397.6 W to 1285.9 W
2024-04-24 05:21:51.941 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1285.9 W to 721.1 W
2024-04-24 05:21:52.966 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 721.1 W to 99.9 W
2024-04-24 05:21:55.532 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.74 W to 11.88 W
2024-04-24 05:22:00.015 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.518 kWh to 789.526 kWh
2024-04-24 05:22:00.025 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.668 kWh to 127.672 kWh
2024-04-24 05:22:10.527 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.88 W to 11.83 W
2024-04-24 05:22:20.289 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 99.9 W to 100.2 W
2024-04-24 05:22:20.291 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.672 kWh to 127.673 kWh
2024-04-24 05:22:22.950 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.83 W to 11.94 W
2024-04-24 05:22:24.011 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.94 W to 11.84 W
2024-04-24 05:22:26.233 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 868.9 W to 875 W
2024-04-24 05:22:26.234 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.526 kWh to 789.533 kWh
2024-04-24 05:22:30.066 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.84 W to 11.93 W
2024-04-24 05:22:32.023 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.6 W to 6.8 W
2024-04-24 05:22:37.950 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.93 W to 11.86 W
2024-04-24 05:22:39.319 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 11.76 W
2024-04-24 05:22:43.824 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.881 kWh to 3343.882 kWh
2024-04-24 05:22:43.824 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 33.74 W to 32.6 W
2024-04-24 05:22:43.826 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 233.141 V to 233.848 V
2024-04-24 05:22:45.943 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 100.2 W to 59.5 W
2024-04-24 05:22:46.967 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 59.5 W to 2.4 W
2024-04-24 05:22:52.950 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.76 W to 11.85 W
2024-04-24 05:22:54.367 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.85 W to 11.82 W
2024-04-24 05:23:00.013 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.533 kWh to 789.541 kWh
2024-04-24 05:23:00.024 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.673 kWh to 127.674 kWh
2024-04-24 05:23:02.328 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 875 W to 810.2 W
2024-04-24 05:23:04.324 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 810.2 W to 0 W
2024-04-24 05:23:07.349 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.82 W to 11.74 W
2024-04-24 05:23:09.633 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.74 W to 11.88 W
2024-04-24 05:23:14.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.517 kWh to 2096.518 kWh
2024-04-24 05:23:14.140 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 35.15 W to 36.16 W
2024-04-24 05:23:14.141 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 229.904 V to 230.129 V
2024-04-24 05:23:22.349 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.88 W to 11.86 W
2024-04-24 05:23:24.888 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 12.19 W
2024-04-24 05:23:26.345 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.541 kWh to 789.542 kWh
2024-04-24 05:23:30.936 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.19 W to 11.78 W
2024-04-24 05:23:32.132 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.8 W to 6.7 W
2024-04-24 05:23:37.352 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.78 W to 11.88 W
2024-04-24 05:23:40.190 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.88 W to 11.98 W
2024-04-24 05:23:40.198 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerMotionSensor_Illumination' changed from 0.06 to 0.10
2024-04-24 05:23:52.352 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.98 W to 11.76 W
2024-04-24 05:23:55.234 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.76 W to 11.98 W
2024-04-24 05:23:58.490 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.98 W to 11.85 W
2024-04-24 05:24:08.490 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.85 W to 12 W
2024-04-24 05:24:10.539 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12 W to 11.66 W
2024-04-24 05:24:20.499 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.4 W to 2.5 W
2024-04-24 05:24:23.495 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.66 W to 12.06 W
2024-04-24 05:24:25.790 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.06 W to 11.96 W
2024-04-24 05:24:31.834 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.96 W to 11.89 W
2024-04-24 05:24:32.240 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.7 W to 6.6 W
2024-04-24 05:24:33.912 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.89 W to 11.83 W
2024-04-24 05:24:37.334 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 0 W to 867.8 W
2024-04-24 05:24:44.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.882 kWh to 3343.883 kWh
2024-04-24 05:24:44.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 32.6 W to 34.34 W
2024-04-24 05:24:44.064 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 233.848 V to 233.811 V
2024-04-24 05:24:48.913 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.83 W to 11.61 W
2024-04-24 05:24:50.961 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.5 W to 829.1 W
2024-04-24 05:24:51.936 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 829.1 W to 1180.7 W
2024-04-24 05:24:58.936 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1180.7 W to 1098.1 W
2024-04-24 05:24:59.936 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1098.1 W to 1.4 W
2024-04-24 05:25:00.012 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.542 kWh to 789.547 kWh
2024-04-24 05:25:00.021 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.674 kWh to 127.677 kWh
2024-04-24 05:25:00.790 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_totalenergy' changed from 6440.396 kWh to 6440.401 kWh
2024-04-24 05:25:00.961 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 1.4 W to 2.4 W
2024-04-24 05:25:03.911 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.61 W to 11.87 W
2024-04-24 05:25:14.054 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.518 kWh to 2096.519 kWh
2024-04-24 05:25:14.055 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 36.16 W to 40.67 W
2024-04-24 05:25:14.055 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 230.129 V to 229.166 V
2024-04-24 05:25:18.912 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.87 W to 11.95 W
2024-04-24 05:25:23.751 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.95 W to 11.78 W
2024-04-24 05:25:28.716 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 867.8 W to 870.7 W
2024-04-24 05:25:28.717 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.547 kWh to 789.554 kWh
2024-04-24 05:25:32.330 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CarportMotionSensor_Illumination' changed from 18.30 to 24.20
2024-04-24 05:25:32.376 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Esszimmer_Licht_Power_Consumption' changed from 6.6 W to 6.7 W
2024-04-24 05:25:33.022 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.78 W to 11.97 W
2024-04-24 05:25:34.753 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.97 W to 12.02 W
2024-04-24 05:25:36.078 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.02 W to 11.74 W
2024-04-24 05:25:49.756 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.74 W to 11.91 W
2024-04-24 05:25:51.123 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.91 W to 11.77 W
2024-04-24 05:26:00.010 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.554 kWh to 789.562 kWh
2024-04-24 05:26:00.752 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PV_dailyenergy' changed from 0.024 kWh to 0.029 kWh
2024-04-24 05:26:04.755 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.77 W to 11.82 W
2024-04-24 05:26:06.175 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.82 W to 11.8 W
2024-04-24 05:26:07.171 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.8 W to 11.86 W
2024-04-24 05:26:09.218 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.86 W to 11.9 W
2024-04-24 05:26:12.959 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 2.4 W to 14.5 W
2024-04-24 05:26:13.934 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 14.5 W to 101 W
2024-04-24 05:26:20.718 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 101 W to 100.7 W
2024-04-24 05:26:22.179 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.9 W to 11.15 W
2024-04-24 05:26:24.265 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.15 W to 11.8 W
2024-04-24 05:26:31.077 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 870.7 W to 869.7 W
2024-04-24 05:26:31.077 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.562 kWh to 789.569 kWh
2024-04-24 05:26:33.527 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.8 W to 11.93 W
2024-04-24 05:26:37.178 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.93 W to 11.8 W
2024-04-24 05:26:39.785 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.8 W to 11.68 W
2024-04-24 05:26:43.834 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Gesamtverbrauch' changed from 3343.883 kWh to 3343.884 kWh
2024-04-24 05:26:43.835 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Leistung' changed from 34.34 W to 43.66 W
2024-04-24 05:26:43.837 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVHaus_Spannung' changed from 233.811 V to 233.904 V
2024-04-24 05:26:52.182 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.68 W to 12.09 W
2024-04-24 05:26:54.551 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 12.09 W to 11.96 W
2024-04-24 05:26:55.043 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.96 W to 11.88 W
2024-04-24 05:26:58.301 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.88 W to 11.87 W
2024-04-24 05:27:00.007 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.569 kWh to 789.576 kWh
2024-04-24 05:27:00.017 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Total_Energy_Consumption' changed from 127.677 kWh to 127.678 kWh
2024-04-24 05:27:09.558 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.87 W to 11.8 W
2024-04-24 05:27:10.353 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.8 W to 11.98 W
2024-04-24 05:27:14.141 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Gesamtverbrauch' changed from 2096.519 kWh to 2096.521 kWh
2024-04-24 05:27:14.142 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Leistung' changed from 40.67 W to 47.6 W
2024-04-24 05:27:14.142 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FRITZPVCarport_Spannung' changed from 229.166 V to 230.141 V
2024-04-24 05:27:20.842 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Kuche_Kaffeemaschine_Power_Consumption' changed from 100.7 W to 100.2 W
2024-04-24 05:27:24.558 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.98 W to 11.82 W
2024-04-24 05:27:25.405 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerStehlampe_Stromverbrauch' changed from 11.82 W to 11.84 W
2024-04-24 05:27:27.330 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 869.7 W to 639.7 W
2024-04-24 05:27:29.329 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Power_Consumption' changed from 639.7 W to 0 W
2024-04-24 05:27:33.748 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad_Heizung_IR_Total_Energy_Consumption' changed from 789.576 kWh to 789.583 kWh
openhab.log right after rebooting the system:
2024-04-24 05:15:46.856 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.1.2 (build Release Build)
2024-04-24 05:15:47.887 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2024-04-24 05:15:47.896 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '50.79786912842059,7.303209900856019'.
2024-04-24 05:15:47.897 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_DE'.
2024-04-24 05:15:47.899 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SI'.
2024-04-24 05:15:58.971 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2024-04-24 05:16:01.399 [INFO ] [g.internal.WizLightingHandlerFactory] -
WiZ Connected Lighting, binding version: v4.0.0.02
2024-04-24 05:16:04.360 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager started at http(s)://192.168.1.100:8080/shelly/manager
2024-04-24 05:16:06.270 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 70...63, base URL = http://localhost:8080)
2024-04-24 05:16:10.998 [INFO ] [mekit.internal.HomekitChangeListener] - Created 0 HomeKit items in instance 1 (no change from prior configuration).
2024-04-24 05:16:14.903 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-04-24 05:16:16.582 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'MEQ1490729' not available, disabling support
2024-04-24 05:16:16.582 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.nio.channels.ClosedSelectorException
2024-04-24 05:16:16.958 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.61.7,address=MEQ1490729,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2024-04-24 05:16:23.096 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-04-24 05:16:45.984 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name 'Chart Temperatur Buero' contains invalid characters, new Datapoint name 'Chart_Temperatur_Buero'
2024-04-24 05:16:45.985 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name 'Remote Angelika * Aussenbeleuchtung' contains invalid characters, new Datapoint name 'Remote_Angelika___Aussenbeleuchtung'
2024-04-24 05:16:45.986 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name 'Remote Angelika * Carport Licht' contains invalid characters, new Datapoint name 'Remote_Angelika___Carport_Licht'
2024-04-24 05:16:46.022 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=CONF_BUTTON_TIME,value=255,defaultValue=255,type=INTEGER,minValue=1,maxValue=254,options=null,readOnly=false,readable=true,unit=minutes,description=CONF_BUTTON_TIME,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
2024-04-24 05:16:50.350 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2024-04-24 05:23:12.919 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-04-24 05:23:30.723 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-04-24 05:24:29.491 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2024-04-24 05:24:45.946 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
Is this a known issue?
Thanks and have a great day!
