Sorry, no!.
What do yout think a car bindig shall deliver?
- km / miles or meters / feet based on
LocaleProvider
? - state of charge in unit
one
? - tire pressure in bar / psi based on
LocaelProvider
? It’s not Hectopascal!
What’s your determination on selecting system default as meter / feet?
You took a bad example! Of course the API can deliver miles
as default but it’s the duty of the binding delevoper to transform the values.
Same quote but the UI cannot provide the right values without correct unit usage. State pattern ok but oh-charts are not showing correct values - see discussion here
After some research I’m able to set metadata unit for new created items within the binding development. Is this harming anyone?
- system default meters- fine
- binding can overwrite this with km
- user can overwrite with whatever unit he wants
