im using OH since a long update history and updated to 5.0.3 on my dockerbased installation (arm64).
the problem is related to addon “Javascript Scripting“ which impacts all rules im using.
the problem: no rule is working anymore with errormessage:
UNINITIALIZED
**HANDLER_INITIALIZING_ERROR**
Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.267 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule a2ca234fc9: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.278 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule ba681445d1: Failed to compile action: 1(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.282 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 28b978c186: Failed to compile action: 1(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.286 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 250b7ccce9: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.294 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 43b646cf4d: Failed to compile action: 1(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.315 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 18243e2718: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.334 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 0f54c1355b: Failed to compile action: 3(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.350 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 6e79cb7e9e: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.355 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 79dc88fb2e: Failed to compile action: 1(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.361 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule 764d3db85e: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
2025-11-27 09:06:08.369 \[ERROR\] \[e.automation.internal.RuleEngineImpl\] - Failed to compile rule waermebedarf: Failed to compile action: 2(Could not initialize class org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine)
what i tried:
uninstall addon javascript and reinstall - no change
can you post the entire log file. The logs you posted are just showing that JSScripting can’t be initialized. Maybe there are some more hints about the reason in the entire log file.
2025-11-27 09:06:03.851 [ERROR] [t.ScriptTransformationServiceFactory] - bundle org.openhab.core.automation.module.script:5.0.3 (164)[org.openhab.core.automation.module.script.ScriptTransformationServiceFactory(104)] : The setScriptEngineFactory method has thrown an exception
2025-11-27 09:06:03.987 [ERROR] [al.provider.ScriptModuleTypeProvider] - bundle org.openhab.core.automation.module.script:5.0.3 (164)[org.openhab.core.automation.module.script.internal.provider.ScriptModuleTypeProvider(112)] : The setScriptEngineFactory method has thrown an exception
2025-11-27 09:06:05.145 [ERROR] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.3 (312)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(460)] : Error during instantiation of the implementation object
2025-11-27 09:06:05.233 [ERROR] [ric.internal.MqttThingHandlerFactory] - bundle org.openhab.binding.mqtt.homeassistant:5.0.3 (312)[org.openhab.binding.mqtt.homeassistant.generic.internal.MqttThingHandlerFactory(459)] : Error during instantiation of the implementation object: Unable to get service for reference $004
2025-11-27 09:06:05.306 [ERROR] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.3 (312)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(460)] : Error during instantiation of the implementation object
2025-11-27 09:06:05.341 [ERROR] [nal.discovery.HomeAssistantDiscovery] - bundle org.openhab.binding.mqtt.homeassistant:5.0.3 (312)[org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery(463)] : Error during instantiation of the implementation object: Unable to get service for reference $001
looks like not only jsscripting is broken. Also HomeAssistantPythonBridge is broken. Thats a strong sign that graalvm is not properly initialized. And this is a sign that something with the installation is broken.
maybe the trace in the beginning of the log file as some more insight.
i switched back to the docker image openhab/openhab:5.0.2
result: all is working fine.
so from my point of view it is not based from my installation which is on docker environment only and the data. the installation is inside the container 5.0.3 - isnt it?
what kind of traces i should enable on 5.0.3 to get more about it?
ok, i have now some good news: after i switched back second time from 5.0.2 to 5.0.3 it runs now without problems. So if im thinking about then it could be that some automatic migration on first update was not working and worked correctly on this secont try, so now all ok and working fine!
so generally summary if someone would have this problem too: switch back to older version and then go again to 5.0.3
but i grepped the older log for that string:
2025-11-26 14:58:40.128 [ERROR] [t.ScriptTransformationServiceFactory] - bundle org.openhab.core.automation.module.script:5.0.3 (164)[org.openhab.core.automation.module.script.ScriptTransformationServiceFactory(96)] : The setScriptEngineFactory method has thrown an exception
java.lang.ExceptionInInitializerError: null
at org.openhab.automation.jsscripting.internal.GraalJSScriptEngineFactory.createScriptEngine(GraalJSScriptEngineFactory.java:99) ~[?:?]
at org.openhab.core.automation.module.script.ScriptTransformationServiceFactory.setScriptEngineFactory(ScriptTransformationServiceFactory.java:72) ~[?:?]
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
