im using oh in docker and just did the upgrade from 5.1.4 to 5.2.0.
But then i got
2026-07-25 15:44:44.774 [WARN ] [g.eclipse.jetty.xml.XmlConfiguration] - Config error at <Call name="addConnector"><Arg>
<New class="org.eclipse.jetty.server.ServerConnector" id="sslConnectorId"><Arg name="server">
<Ref refid="Server"/>
</Arg><Arg name="factories">
<Array type="org.eclipse.jetty.server.ConnectionFactory"><Item>
<New class="org.eclipse.jetty.server.SslConnectionFactory"><Arg name="sslContextFactory">
<Ref refid="sslContextFactory"/>
</Arg><Arg name="next">alpn</Arg></New>
</Item><Item>
<New class="org.eclipse.jetty.alpn.server.ALPNServerConnectionFactory"><Arg>h2,http/1.1</Arg></New>
</Item><Item>
<New class="org.eclipse.jetty.http2.server.HTTP2ServerConnectionFactory"><Arg name="config">
<Ref refid="httpConfig"/>
</Arg></New>
</Item><Item>
<New class="org.eclipse.jetty.server.HttpConnectionFactory"><Arg name="config">
</Arg></New>
</Item></Array>
</Arg><Set name="name">
<SystemProperty name="jetty.host" default="0.0.0.0"/>:<SystemProperty name="org.osgi.service.http.port.secure" default="8443"/>
</Set><Set name="host">
<SystemProperty name="jetty.host"/>
</Set><Set name="port">
</Set><Set name="idleTimeout">
<SystemProperty name="https.timeout" default="30000"/>
</Set></New>
</Arg></Call>
2026-07-25 15:44:44.834 [WARN ] [ce.jetty.internal.JettyServerWrapper] - Problem parsing file:///openhab/runtime/etc/jetty.xml: null
java.lang.reflect.InvocationTargetException
But the jetty.xml is existing inside the container.
The update itself it told me SUCCESS: openHAB updated from 5.1.4 to 5.2.0
Former i had never as i remember such jetty problem.
Is there something what i missed on updating? Would be nice if someone coud give me a hint…
