My OH running as docker for some time now, no issues.
Recently, after some time, OH stop working partially, mainly the rule engine
Restarting the docker fixing it.
In the logs I see some permission denied, and some write errors, but how come its solved with reboot ?
Few weeks ago I had full SSD card issue (Docker json log file was 499GB!) but its solved and no such issues anymore. I’ve deleted the cache and tmp directories and rebooted. it happened again after.
Logs attached.
What should I do ?
All other dockers work flawless so I’m no suspecting the SSD as hardware (Boot from SSD as well)
Again, Rules not working
This time I don’t see anything in the logs that might suggest what’s the issue.
before reboot
2020-12-20 07:44:01.808 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'dShuttersKRLight' received command RSLH
2020-12-20 07:44:01.814 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'dShuttersKRLight' changed from NULL to RSLH
and now rule should fire
rule “KidsRoomLight”
Item dShuttersKRLight received update
if (dShuttersKRLight.state.toString.contains(“RSLH”)) {
sendCommand(KRWRS_Shutter, 33)
sendCommand(KRNRS_Shutter, 33)
sendCommand(dShuttersKRLight, “x”)
if (dShuttersKRLight.state.toString.contains(“RSDW”)) {
sendCommand(gShuttersKR, DOWN)
if (dShuttersKRLight.state.toString.contains(“RSUP”)) {
sendCommand(gShuttersKR, UP)
and now after reboot
2020-12-20 07:50:54.121 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘dShuttersKRLight’ received command RSLH
2020-12-20 07:50:54.126 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘dShuttersKRLight’ changed from NULL to RSLH
2020-12-20 07:51:05.545 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KRWRS_Shutter’ received command 33
2020-12-20 07:51:05.549 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘KRWRS_Shutter’ predicted to become 33
2020-12-20 07:51:05.626 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KRNRS_Shutter’ received command 33
2020-12-20 07:51:05.628 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘dShuttersKRLight’ received command x
2020-12-20 07:51:05.630 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item ‘gShutters’ changed from 0 to UP through KRWRS_Shutter
2020-12-20 07:51:05.631 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item ‘gShuttersKR’ changed from 0 to UP through KRWRS_Shutter
2020-12-20 07:51:05.632 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KRWRS_Shutter’ changed from 0 to 33
2020-12-20 07:51:05.637 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘KRNRS_Shutter’ predicted to become 33
2020-12-20 07:51:05.700 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item ‘gShuttersKR’ changed from 0 to DOWN through KRNRS_Shutter
2020-12-20 07:51:05.704 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KRNRS_Shutter’ changed from 0 to 33
2020-12-20 07:51:05.712 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item ‘gShutters’ changed from 0 to UP through KRNRS_Shutter
2020-12-20 07:51:05.718 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘dShuttersKRLight’ changed from RSLH to x
