`oh-button` with `ruleAction`
I’ve got this widget:
                          - component: oh-card
                              title: Avondlijke gezeligheid
                            slots:
                              content:
                                - component: oh-button
                                    text: Lampjes in eetkamer en salon aansteken
                                    round: true
                                    outline: true
                                    raised: true
                                    fill: true
                                    action: rule
                                    actionRule: gezellig
I’ve got a scene with UID gezellig.
But the above configuration doesn’t seem to work…
Does anyone see the error?
The yaml is correct, so all I can suggest is that you double check the UID of the scene and check the logs to see if the expected commands are actually being broadcast.
The only other possibility is that this is only a part of the widget and you’ve haven’t shown the rest. It’s possible that other components of the widget may be interfering with the ability to actually click on the button.
