OH Log Viewer on RPI 5 not launching in Browser
  • Platform information:
    • Hardware: Raspberry Pi 5/4GB/64 GB
    • OS: Bookworm
    • Java Runtime Environment: openJDK 17.0.13
    • openHAB version: 4.3.2
  • Issue of the topic:
    Installed OH 4.3.2 on my new RPI 5 and restored a backup from my RPI 3+ (running OH 4.3.2).
    Everything seems to be working except for OH Log Viewer when launched from the UI.
    There are no error logs when I try to launch it from the UI. It tries to open the URL [OH IP]:9001 but I get “ERR_CONNECTION_REFUSED”.
    Any help would be greatly appreciated!
Did you install frontail ? Without, your error message is logical.
In openhabian-config → Optional Components, I see the options for frontail are now DEPRECATED. Should I be using something else now other than frontail?
It is deprecated, but you still can install it. The Link you tried to use is pointing to a frontail installation.
There is also a built in logviewer under developer tools.
Awesome! It’s working now. Thanks!
