I’ve recently upgraded my openhabian setup (updated background raspbian via openhabian-config first, then upgraded openhab also via the interface) from 2.54 to 2.57 to be able to access the iCalendar binding.
Unfortunately, my zwave controller went off line.
I tried deleting and installing the thing in paperui, no dice
- changing the port back and forth in paperui
- cleared the cache
- reset the pi
- going back into openhabian-config and re-applying the razzberry fixes
- deleting and re-installing the z-wave binding
- again toggling the zwave port (this used to fix issues for me, so I do it intermittently - not that it’s solved anything in years).
When I look at my logs, I can see zwave ‘chatter’, but the zwave controller shows up as “Offline - Bridge Offline”. Needless to say, there isn’t any control of any of the zwave devices.
Logs, filtered for ‘zwave’:
2020-08-09 23:35:06.721 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been uninstalled.
2020-08-09 23:35:10.779 [INFO ] [internal.service.FeaturesServiceImpl] - Adding features: openhab-binding-zwave/[2.5.7,2.5.7]
2020-08-09 23:35:15.742 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.addons.bundles/org.openhab.binding.zwave/[2.5.0,2.6)
2020-08-09 23:35:15.792 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.addons.bundles/org.openhab.binding.zwave/[2.5.0,2.6)
2020-08-09 23:35:16.329 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.7
2020-08-09 23:35:16.602 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2020-08-09 23:35:21.223 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.227 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.235 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node19' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.237 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node14' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.238 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node13' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.239 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node12' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.243 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node11' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.245 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node18' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.246 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node17' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.249 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node16' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.252 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node15' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.254 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node32' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.255 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node31' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.255 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-08-09 23:35:21.256 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node30' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.258 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node35' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.259 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node34' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.260 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node33' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.261 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node20' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.263 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.264 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node5' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.265 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.267 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node7' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.269 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.271 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node24' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.272 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node29' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.273 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node28' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.275 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node27' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-08-09 23:35:21.426 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a204e4d4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:35:21.439 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a204e4d4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.569 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node2' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.578 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.589 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node19' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.600 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node13' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.602 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node14' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.605 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node3' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.614 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node12' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.620 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node19' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.625 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node14' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.632 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.637 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node13' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.641 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.648 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node18' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.655 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node18' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.658 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node11' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.665 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node15' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.672 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node17' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.674 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node32' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.676 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node16' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.679 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node11' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.694 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node15' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.697 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node16' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.708 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node17' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.712 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node32' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.714 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node31' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.719 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node31' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.727 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node34' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.729 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node33' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.732 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node35' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.738 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node30' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.741 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node20' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.742 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node33' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.752 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node34' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.767 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node30' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.772 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node20' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.775 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.778 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node5' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.781 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node35' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.784 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node7' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.792 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.798 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.803 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.815 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node4' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.817 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node29' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.825 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.828 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.831 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.834 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node28' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.836 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node27' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.839 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node29' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.847 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node24' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-08-09 23:35:21.851 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node28' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.858 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node27' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:21.864 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node24' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:35:26.495 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 40 to 0
2020-08-09 23:35:26.499 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 10 to 0
2020-08-09 23:35:26.504 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 14 to 0
2020-08-09 23:35:26.506 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 78 to 0
2020-08-09 23:35:26.509 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_cse changed from 2 to 0
2020-08-09 23:35:26.518 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-08-09 23:35:26.519 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-08-09 23:35:29.562 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 0 to 1
2020-08-09 23:35:31.060 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 0 to 1
2020-08-09 23:35:31.068 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 1 to 2
2020-08-09 23:35:31.070 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 2 to 3
2020-08-09 23:35:31.072 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 3 to 4
2020-08-09 23:35:31.073 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 4 to 5
2020-08-09 23:35:31.074 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 5 to 6
2020-08-09 23:35:31.080 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 1 to 2
2020-08-09 23:35:31.126 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 0 to 1
2020-08-09 23:35:33.144 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 1 to 2
2020-08-09 23:35:33.151 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 6 to 7
2020-08-09 23:35:33.156 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 7 to 8
2020-08-09 23:35:33.158 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 8 to 9
2020-08-09 23:35:33.167 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 9 to 10
2020-08-09 23:35:33.169 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 10 to 11
2020-08-09 23:35:33.170 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 11 to 12
2020-08-09 23:35:34.644 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 2 to 3
2020-08-09 23:35:34.656 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_cse changed from 0 to 1
2020-08-09 23:35:35.192 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 2 to 3
2020-08-09 23:35:37.004 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 3 to 4
2020-08-09 23:35:37.216 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 4 to 5
2020-08-09 23:35:37.218 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 12 to 13
2020-08-09 23:35:37.219 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 3 to 4
2020-08-09 23:35:38.714 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 13 to 14
2020-08-09 23:35:38.716 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 4 to 5
2020-08-09 23:36:07.018 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 5 to 6
2020-08-09 23:36:07.443 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 0 to 1
2020-08-09 23:36:11.515 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 5 to 6
2020-08-09 23:36:43.029 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 6 to 7
2020-08-09 23:36:46.027 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 7 to 8
2020-08-09 23:36:49.026 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 8 to 9
2020-08-09 23:36:50.527 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 14 to 15
2020-08-09 23:36:50.531 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 15 to 16
2020-08-09 23:36:52.030 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 16 to 17
2020-08-09 23:36:52.034 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 17 to 18
2020-08-09 23:36:52.036 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 18 to 19
2020-08-09 23:36:52.037 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 19 to 20
2020-08-09 23:36:53.533 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 20 to 21
2020-08-09 23:36:53.536 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 21 to 22
2020-08-09 23:36:53.541 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 22 to 23
2020-08-09 23:36:53.543 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 23 to 24
2020-08-09 23:36:53.546 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 24 to 25
2020-08-09 23:36:53.548 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 25 to 26
2020-08-09 23:36:53.549 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 9 to 10
2020-08-09 23:36:53.580 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 27: Not initialized (ie node unknown), ignoring message.
2020-08-09 23:37:00.493 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 26 to 27
2020-08-09 23:37:03.486 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 10 to 11
2020-08-09 23:37:06.486 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 11 to 12
2020-08-09 23:37:07.261 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 1 to 2
2020-08-09 23:37:07.987 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 27 to 28
2020-08-09 23:37:09.491 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 28 to 29
2020-08-09 23:37:09.498 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 29 to 30
2020-08-09 23:37:09.501 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 30 to 31
2020-08-09 23:37:09.504 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 31 to 32
2020-08-09 23:37:10.987 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 32 to 33
2020-08-09 23:37:10.994 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 33 to 34
2020-08-09 23:37:11.007 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 34 to 35
2020-08-09 23:37:11.010 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 35 to 36
2020-08-09 23:37:13.987 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 12 to 13
2020-08-09 23:37:16.986 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 13 to 14
2020-08-09 23:37:18.490 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 36 to 37
2020-08-09 23:37:18.496 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 37 to 38
2020-08-09 23:37:18.498 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 38 to 39
2020-08-09 23:37:18.501 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 39 to 40
2020-08-09 23:37:19.989 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 40 to 41
2020-08-09 23:37:19.992 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 41 to 42
2020-08-09 23:37:19.994 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 42 to 43
2020-08-09 23:37:21.492 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 43 to 44
2020-08-09 23:37:21.494 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 44 to 45
2020-08-09 23:37:25.992 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 45 to 46
2020-08-09 23:37:25.994 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 14 to 15
2020-08-09 23:37:28.997 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 46 to 47
2020-08-09 23:37:29.000 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 47 to 48
2020-08-09 23:37:29.002 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 48 to 49
2020-08-09 23:37:29.004 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 49 to 50
2020-08-09 23:37:30.490 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 50 to 51
2020-08-09 23:37:30.504 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 51 to 52
2020-08-09 23:37:30.507 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 52 to 53
2020-08-09 23:37:30.509 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 53 to 54
2020-08-09 23:37:31.988 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 54 to 55
2020-08-09 23:37:33.486 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 55 to 56
2020-08-09 23:37:36.487 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 15 to 16
2020-08-09 23:37:38.190 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 2 to 3
2020-08-09 23:37:38.606 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 3 to 4
2020-08-09 23:37:38.808 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 4 to 5
2020-08-09 23:37:39.485 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 5 to 6
2020-08-09 23:37:40.989 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 56 to 57
2020-08-09 23:37:40.998 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 57 to 58
2020-08-09 23:37:41.000 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 58 to 59
2020-08-09 23:37:42.492 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 59 to 60
2020-08-09 23:37:42.495 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 60 to 61
2020-08-09 23:37:43.990 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 61 to 62
2020-08-09 23:37:45.488 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 62 to 63
2020-08-09 23:37:45.493 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 63 to 64
2020-08-09 23:37:45.495 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 64 to 65
2020-08-09 23:37:45.497 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 65 to 66
2020-08-09 23:37:48.488 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 16 to 17
2020-08-09 23:37:51.496 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 66 to 67
2020-08-09 23:37:51.507 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 67 to 68
2020-08-09 23:37:51.509 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 68 to 69
2020-08-09 23:37:51.512 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 69 to 70
2020-08-09 23:37:51.514 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 17 to 18
2020-08-09 23:37:51.531 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 27: Not initialized (ie node unknown), ignoring message.
2020-08-09 23:38:07.070 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 18 to 19
2020-08-09 23:38:10.068 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 19 to 20
2020-08-09 23:38:27.239 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 6 to 7
2020-08-09 23:38:28.736 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 20 to 21
2020-08-09 23:38:31.738 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 21 to 22
2020-08-09 23:38:37.283 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 6 to 7
2020-08-09 23:38:38.576 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 70 to 71
2020-08-09 23:38:40.066 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 22 to 23
2020-08-09 23:39:07.295 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 7 to 8
2020-08-09 23:39:08.781 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 8 to 9
2020-08-09 23:39:37.088 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 7 to 8
2020-08-09 23:39:49.503 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 23 to 24
2020-08-09 23:39:50.997 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 24 to 25
2020-08-09 23:39:53.999 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 25 to 26
2020-08-09 23:39:55.503 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 71 to 72
2020-08-09 23:39:55.505 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 26 to 27
2020-08-09 23:39:56.998 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 72 to 73
2020-08-09 23:39:58.495 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 73 to 74
2020-08-09 23:40:00.000 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 74 to 75
2020-08-09 23:40:01.506 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 75 to 76
2020-08-09 23:40:01.511 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 76 to 77
2020-08-09 23:40:01.514 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 77 to 78
2020-08-09 23:40:02.999 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 78 to 79
2020-08-09 23:40:04.497 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 79 to 80
2020-08-09 23:40:07.100 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 27 to 28
2020-08-09 23:40:10.096 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 28 to 29
2020-08-09 23:40:19.686 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 29 to 30
2020-08-09 23:40:22.681 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 30 to 31
2020-08-09 23:40:22.710 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 29: Not initialized (ie node unknown), ignoring message.
and a snip after removing and re-adding the z-wave controller thing:
2020-08-09 23:55:37.602 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-08-09 23:55:37.618 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a204e4d4' changed from UNINITIALIZED to INITIALIZING
2020-08-09 23:55:37.633 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:a204e4d4' has been updated.
2020-08-09 23:55:37.636 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a204e4d4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.644 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node3' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.673 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.676 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.679 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node19' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.684 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node14' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.689 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node12' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.692 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node13' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.695 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node19' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.699 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.701 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from NULL to 34
2020-08-09 23:55:37.704 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_sof-zwave:serial_zstick:a204e4d4:serial_sof' has been added.
2020-08-09 23:55:37.707 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node18' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.711 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node13' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.715 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node17' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.717 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node11' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.720 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from NULL to 1
2020-08-09 23:55:37.722 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_ack-zwave:serial_zstick:a204e4d4:serial_ack' has been added.
2020-08-09 23:55:37.732 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node18' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.744 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node14' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.762 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.769 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node11' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.828 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node15' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.832 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node16' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.835 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node17' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.838 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_nak changed from NULL to 0
2020-08-09 23:55:37.841 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node32' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.843 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_nak-zwave:serial_zstick:a204e4d4:serial_nak' has been added.
2020-08-09 23:55:37.846 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node31' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.849 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node30' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.853 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node16' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.856 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from NULL to 5
2020-08-09 23:55:37.859 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_can-zwave:serial_zstick:a204e4d4:serial_can' has been added.
2020-08-09 23:55:37.870 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node35' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.877 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node30' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.883 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node15' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.890 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node32' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.894 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node33' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.897 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node34' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.903 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node35' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.907 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from NULL to 95
2020-08-09 23:55:37.909 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_oof-zwave:serial_zstick:a204e4d4:serial_oof' has been added.
2020-08-09 23:55:37.911 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node20' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.914 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.926 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node33' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.935 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node31' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.937 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.960 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node5' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.961 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node34' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.970 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.973 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node20' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.977 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.978 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node24' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.980 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node7' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.989 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:37.991 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.992 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node29' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:37.997 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node28' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:38.001 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_cse changed from NULL to 3
2020-08-09 23:55:38.003 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_a204e4d4_serial_cse-zwave:serial_zstick:a204e4d4:serial_cse' has been added.
2020-08-09 23:55:38.035 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node24' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.044 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.050 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node29' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.053 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.055 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node28' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.057 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node27' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-08-09 23:55:38.061 [hingStatusInfoChangedEvent] - 'zwave:device:a204e4d4:node27' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-08-09 23:55:38.675 [vent.ItemStateChangedEvent] - systeminfo_computer_openhab_memory_availablePercent changed from 82.5 to 82.4
2020-08-09 23:55:38.677 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 82.4
2020-08-09 23:55:42.663 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-08-09 23:55:42.666 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_sof changed from 34 to 0
2020-08-09 23:55:42.666 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-08-09 23:55:42.672 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_ack changed from 1 to 0
2020-08-09 23:55:42.672 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-08-09 23:55:42.682 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-08-09 23:55:42.688 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-08-09 23:55:42.688 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_can changed from 5 to 0
2020-08-09 23:55:42.697 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-08-09 23:55:42.702 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 95 to 0
2020-08-09 23:55:42.705 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-08-09 23:55:42.708 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_cse changed from 3 to 0
2020-08-09 23:55:44.196 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 2
2020-08-09 23:55:44.200 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a204e4d4_serial_oof changed from 0 to 1
Thanks for any further direction/ideas you may have.
Raspberry pi 4b rev 1.1, 4gb
openhabian 2.57
razzbery hat
