after running some updates on packages (other than OpenHAB) on my Pi the UI does only respond to http - no https
openhab.log:
2017-02-09 21:52:29.955 [WARN ] [org.eclipse.jetty.io.nio ] - handle failed
java.lang.NoClassDefFoundError: Could not initialize class sun.security.ssl.SupportedEllipticCurvesExtension
at sun.security.ssl.HelloExtensions.(HelloExtensions.java:82) ~[na:1.8.0_121]
at sun.security.ssl.HandshakeMessage$ClientHello.(HandshakeMessage.java:245) ~[na:1.8.0_121]
at sun.security.ssl.ServerHandshaker.processMessage(ServerHandshaker.java:220) ~[na:1.8.0_121]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[na:1.8.0_121]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:966) ~[na:1.8.0_121]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:963) ~[na:1.8.0_121]
at java.security.AccessController.doPrivileged(Native Method) ~[na:1.8.0_121]
at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1416) ~[na:1.8.0_121]
at org.eclipse.jetty.io.nio.SslConnection.process(SslConnection.java:370) ~[org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SslConnection.access$900(SslConnection.java:43) ~[org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SslConnection$SslEndPoint.fill(SslConnection.java:661) ~[org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.fill(HttpParser.java:1030) ~[org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:275) ~[org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) ~[org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SslConnection.handle(SslConnection.java:191) ~[org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606) ~[org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_121]
any ideas ?
many thanks
Andreas
