Migrating from OH1 to OH2, I’m following @chris’s guide as well as this book using the latest snapshots of OH2 and HABmin as of today.
Installation and setting up of the controller went without problems.
When I click on the Discover → Z-Wave Binding in HABmin, all my nodes are detected and put in the Inbox but none of them is actually identified and all of their Manufacturer/Type ID are set to ffff if I add them as things.
In the habmin guide above it says I need to put the devices in discover mode again. Is that true even if the devices are already in a network with the controller? I want to confirm before I start digging out all my devices from their locations to click the inclusion button.
Here is a snippet of the log:
2016-06-08 11:30:18.076 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_155308f567d_serial_sof changed from 347 to 348
2016-06-08 11:30:18.077 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 04 12 60 0D 02 00 32 02 21 64 00 36 92 EE 00 3B 00 36 92 E8 D2
2016-06-08 11:30:18.077 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-06-08 11:30:18.077 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 04 12 60 0D 02 00 32 02 21 64 00 36 92 EE 00 3B 00 36 92 E8 D2
2016-06-08 11:30:18.077 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 04 12 60 0D 02 00 32 02 21 64 00 36 92 EE 00 3B 00 36 92 E8 D2
2016-06-08 11:30:18.078 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 12 60 0D 02 00 32 02 21 64 00 36 92 EE 00 3B 00 36 92 E8
2016-06-08 11:30:18.078 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DETAILS)
2016-06-08 11:30:18.078 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class MULTI_INSTANCE
2016-06-08 11:30:18.078 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 4: Received Multi-instance/Multi-channel Request
2016-06-08 11:30:18.078 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 4: Requested Command Class = METER (0x32)
2016-06-08 11:30:18.078 [ERROR] [class.ZWaveMultiInstanceCommandClass] - NODE 4: Endpoint 2 not found. Cannot set command classes.
2016-06-08 11:30:18.078 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
