I’ve just upgraded from a stable OH V2.0 into a problematic OH V2.1. My main problem is that it takes several variable minutes for my RFXCOM device to come online meaning that it spits errors when persistance restores the values to an item that doesn’t have a working bridge, which goes on to cause problems. An error is below
[WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command 'OFF' for item 'TopStairLightsDisable' to handler for channel 'rfxcom:lighting1:10351c54:command', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
The bridge came online 7 minutes and 10 seconds after it finished loading default.items, the next time it took.5 minutes and 13 seconds, and the persistance works at this lower level of delay
The USB connection to the bridge is via a hard link, and apart from the onboard bluetooth its the only thing plugged into the Pi3
Is there a way of either hurrying this up, or delaying persistence until it announces its online status?
I’ve already cleared out the tmp and cache folders chasing a previous fault, as well as uninstalled and reinstalled the RFXCom binding
