So I guess it’s on oracle now to work on this issue, it would still be nice to downgrade XChart to fix this. There was absolutely no point in upgrading that library.
According to these threads this is used to install the 32bit dependencies. I think we can remove it afterwards. But however, it works and that is from the user perspective the important thing.
In fact the analysis has already be done earlier in this topic and the problem is apparently rhe XChart library. So the solution is to wait for a library update and then use it in OH.
The analysis was done by me, also an issue in the XChart library was opened by me. It is however unlikely that an updated version will fix the issue as it’s not really in the XChart library itself but it seems to be an issue with java itself. Instead of waiting for a fix and leaving us with a broken implementation, we should downgrade to the version that was used before the issue was created, like in OH 2.0. Then 64 Bit can be used, which is a big advantage. It is easier to maintain the 64 Bit compatibility now, than to change everything later as there are many things not 64 Bit compatible.
The PR with the Upgrade should never have been merged as it is causing an issue and fixing exactly ZERO other issues, you see that something is wrong here?
OH1 was working fine on arm64, so it’s probably not because of that. @Kai wrote, that he doesn’t know why it was upgraded, and also there is absolutely no documentation. We should downgrade, as that would fix the issue that was created.
In this thread, more specifically in this post: OH2.1: Fonts Scrambled
Or did I misunderstand that? I asked why that version was chosen, and you wrote that you can only tell me what was written in the change log.
Anyways, do you know why it was upgraded and why this version was chosen?
Bring chart servlet up to openHAB 1.8.3 look and functionality, fixes #2829.
Sounds to me as if this was done in openHAB 1.8 already before, so if there had been a regression, it was many years ago already. Downgrading would revert the new features, so that is not a straight forward option. As mentioned before, it should rather be addressed in the upstream project, so that there is an upgrade path for us, not a downgrade.
In the XChart Project the issue is open, even though I think it’s a java issue as it only affects arm64, if the issue would also exist on amd64 it would be a 64 Bit issue, but that doesn’t seem to be the case.
Using zulu 64 Bit java is fine aswell, so it’s oracle 64 bit on arm64 related. I guess it’s up to oracle to figure out whats going on there, I switched to zulu for now and it works fine.
I downloaded the arm64 binaries from the zulu website, extracted them and did an Update-Alternative to register the java command. After selecting the right alternative and restarting OpenHAB it works.
If you need detailed instructions let me know, I can write them when I’m at the office. There I have all the information on what I did.
