OH2.1: Fonts Scrambled
It’s not my real office work but I can work on it at the office if I want to.
cd /usr/bin
mkdir zulu
cd zulu/
wget http://cdn.azul.com/zulu-embedded/bin/ezdk-1.8.0_144-8.23.0.70-eval-linux_aarch64.tar.gz
gunzip ezdk-1.8.0_144-8.23.0.70-eval-linux_aarch64.tar.gz
tar -xf ezdk-1.8.0_144-8.23.0.70-eval-linux_aarch64.tar
rm -rf ezdk-1.8.0_144-8.23.0.70-eval-linux_aarch64.tar
sudo update-alternatives --install /usr/bin/java java /usr/zulu/ezdk-1.8.0_144-8.23.0.70-eval-linux_aarch64/bin/java 2000
That should install it and select it as default.
@Flole
Thank you so much ! Works instantly.
This should be made sticky. At least for all ARM64 owners with ODROIDs.
May I add a small correction:
   sudo update-alternatives --install /usr/bin/java java /usr/**bin/**zulu/ezdk-1...
After that command I had to issue - another:
    update-alternatives --config java
Then I can select the new alternative and voila !
Thanks again !
Gerry
