Hi all,
Seems my issue has re-started where grafana graphs stop showing in either the browser or IOS app and I get the following errors in the openhab log, I know grafana is working fine as I can view the logs direct.
This issue only started after upgrading to OH2.2, ive tried just restart OH when the error occurs but that doesnt help,this all worked fine in OH2.1
2017-12-27 09:43:36.561 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:43:39.147 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:43:39.734 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:43:39.750 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.919 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.925 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.927 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.967 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.970 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:06.975 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:07.080 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:07.088 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:09.583 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:13.541 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:13.816 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:13.818 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:13.879 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:13.881 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:21.932 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:21.931 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:22.586 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:28.956 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:28.981 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:28.984 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.099 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.123 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.381 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.383 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.426 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.429 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:44:44.431 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:45:07.418 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2017-12-27 09:45:07.424 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
Configuration in sitemap
Frame {
Image item=System_Temperature_CPU
url="http://192.168.1.176:3000/render/dashboard-solo/db/openhab-system?refresh=5m&orgId=1&panelId=6&from=now-1d&to=now&width=1000&height=320&tz=UTC%2B00%3A00"
refresh=60000
url="http://192.168.1.176:3000/render/dashboard-solo/db/openhab-system?refresh=5m&orgId=1&panelId=6&from=now-31d&to=now&width=1000&height=320&tz=UTC%2B00%3A00"
refresh=60000
url="http://192.168.1.176:3000/render/dashboard-solo/db/openhab-system?refresh=5m&orgId=1&panelId=6&from=now-183d&to=now&width=1000&height=320&tz=UTC%2B00%3A00"
refresh=60000
OH2.2 and grafana run on separate Pi 3 to keep the load and logging away from the main OH platform.
OH2.2
# openhab-cli info
Version: 2.2.0 (Build)
User: openhab (Active Process 11942)
User Groups: openhab tty dialout video
Directories: Folder Name | Path | User:Group
OPENHAB_HOME | /usr/share/openhab2 | openhab:openhab
OPENHAB_RUNTIME | /usr/share/openhab2/runtime | openhab:openhab
OPENHAB_USERDATA | /var/lib/openhab2 | openhab:openhab
OPENHAB_CONF | /etc/openhab2 | openhab:openhab
OPENHAB_LOGDIR | /var/log/openhab2 | root:root
OPENHAB_BACKUPS | /var/lib/openhab2/backups | root:root
URLs: http://192.168.1.142:8080
https://192.168.1.142:8443
# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
Cheers
Kevin
