I’m on snapshot 2.4 1440.
If I delete an item or a group from item file, I get this error log:
2018-11-24 20:42:25.915 [INFO ] [org.openhab.core.compat1x ] - FrameworkEvent INFO - org.openhab.core.compat1x
java.io.IOException: Exception in opening zip file: C:\OpenHAB2\userdata\cache\org.eclipse.osgi\284\0\bundleFile
Caused by: java.io.FileNotFoundException: C:\OpenHAB2\userdata\cache\org.eclipse.osgi\284\0\bundleFile (Das System kann den angegebenen Pfad nicht finden)
at java.util.zip.ZipFile.open(Native Method) ~[?:?]
2018-11-24 20:42:25.915 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.items.internal.ItemUIRegistryDelegate@171c07a" about the "REMOVED" event: org/openhab/core/items/GroupItem
java.lang.NoClassDefFoundError: org/openhab/core/items/GroupItem
Caused by: java.lang.ClassNotFoundException: org.openhab.core.items.GroupItem cannot be found by org.openhab.core.compat1x_2.4.0.201811241129
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
Full log:
delete item.txt (39.7 KB)
