Elsing
(Markus)
January 3, 2020, 9:20pm
1
Hi
the new nice Frontail log viewer seems not to work with Safari. I am accessing my RP3 openhabian setup with https, but when I try to go to Frontail, it tries to fall back to an unsecure connection. There is probably a way to fix this ?
Thanks in advance, Markus
I believe frontail, by default is only http on port 9001. You could set yup an nginx secure reverse proxy as detailed on our security documentation page.
Elsing
(Markus)
January 3, 2020, 9:24pm
3
Ah, similar to what one does for 8080 and 443. I’ll try this and report back.
Thanks ! M.
Elsing
(Markus)
January 3, 2020, 10:17pm
4
Awesome, works. I added to my nginx setup /etc/nginx/sites-enabled/openhab the following reverse proxy setup for channel 444:
## Reverse Proxy to Frontail
server {
listen 444 ssl;
server_name ...myip..;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
## Secure Certificate Locations
ssl_certificate /etc/ssl/certs/openhab.crt;
ssl_certificate_key /etc/ssl/certs/openhab.key;
location / {
proxy_pass http://localhost:9001/;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
## in this case we allow for now password
satisfy any;
allow all;
## Password Protection
auth_basic "Username and Password Required";
auth_basic_user_file /etc/nginx/.htpasswd;
## Let's Encrypt webroot location
location /.well-known/acme-challenge/ {
root /var/www/localhost;
I then had to hack the dashboard file in /etc/openhab/services/dashboard.cfg, searching for frontail and replacing the link:
frontail.link-url=https://{HOSTNAME}:444
Works like a charm with safari.
Thanks for the help, Markus
