Hello !
I am struggling with a stupid problem. I cannot find the IHC2 binding in PaperUI
Only the OH1.x version is there.
What am I doing wrong?
Hello !
IHC2 binding hasn´t been merged into OH2 yet. You´ll need to grap the binding manually… Or you could use OH1 binding. (OH2 binding is MUCH better though)
@pauli_anttila can probably supply you with an updated link for the binding, otherweise I can provide one later.
Hi!
Thank you. I’d love a link to the binding
IHC2 binding is merged to OH2 already, but as it’s merged after 2.5.0 Milestone 1 (M1) build and milestone builds are broken currently, there is no other release than daily snapshot available which contains the new binding.
But cant he use the link to the jar from the danish IHC forum, and install it manually?
My understanding is that recent snapshots are no longer compatible with OH 2.5 M1 due to the API changes from merging ESH back into OH.
I downloaded a snapshot of oh2 bindings and put the ihc bindind in the addons-folder.
In the log, I see this
2019-05-24 16:55:09.195 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.ihc-2.5.1M.jar
org.osgi.framework.BundleException: **Could not resolve module**: org.openhab.binding.ihc [191]
2019-05-24 16:56:46.338 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTING - org.openhab.binding.ihc
2019-05-24 16:56:46.380 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent RESOLVED - org.openhab.binding.ihc
2019-05-24 16:56:46.539 [DEBUG] [ab.binding.ihc.internal.IhcActivator] - IHC / ELKO LS binding has been started.
2019-05-24 16:56:46.542 [DEBUG] [org.openhab.binding.ihc ] - BundleEvent STARTED - org.openhab.binding.ihc
2019-05-24 16:56:46.604 [DEBUG] [org.openhab.binding.ihc ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.ihc.IhcBindingProvider}={service.id=319, service.bundleid=191, service.scope=bundle, component.name=org.openhab.binding.ihc.genericbindingprivider, component.id=179} - org.openhab.binding.ihc
2019-05-24 16:56:46.746 [INFO ] [org.apache.felix.fileinstall ] - Started bundle: file:/usr/share/openhab2/addons/org.openhab.binding.ihc-2.5.1M.jar
2019-05-24 16:56:46.749 [INFO ] [org.apache.felix.fileinstall ] - Started bundle: file:/usr/share/openhab2/addons/org.openhab.binding.ihc-2.5.1M.jar
2019-05-24 16:56:50.988 [DEBUG] [org.openhab.binding.ihc ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={service.id=366, service.bundleid=191, service.scope=bundle, event.topics=openhab/*, service.pid=org.openhab.ihc, component.name=org.openhab.binding.ihc, component.id=181} - org.openhab.binding.ihc
2019-05-24 16:56:51.030 [DEBUG] [nhab.binding.ihc.internal.IhcBinding] - allBindingsChanged
2019-05-24 16:56:51.034 [DEBUG] [nhab.binding.ihc.internal.IhcBinding] - Configuration updated, config true
- Initialize SSL context
2019-05-24 16:56:54.928 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Connection successfully opened
2019-05-24 16:56:55.142 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Loading IHC /ELKO LS project file from controller...
2019-05-24 16:56:55.652 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Number of segments: 12
2019-05-24 16:56:55.655 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Segmentation size: 7500
2019-05-24 16:56:55.656 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 0
2019-05-24 16:56:56.033 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 1
2019-05-24 16:56:56.377 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 2
2019-05-24 16:56:56.720 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 3
2019-05-24 16:56:57.175 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 4
2019-05-24 16:56:57.520 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 5
2019-05-24 16:56:57.859 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 6
2019-05-24 16:56:58.609 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 7
2019-05-24 16:56:58.967 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 8
2019-05-24 16:56:59.450 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 9
2019-05-24 16:56:59.883 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 10
2019-05-24 16:57:00.266 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Downloading segment 11
2019-05-24 16:57:00.453 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - File size before base64 encoding: 111508 bytes
2019-05-24 16:57:00.562 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - File size after base64 encoding: 83631 bytes
2019-05-24 16:57:01.361 [DEBUG] [penhab.binding.ihc.ws.IhcProjectFile] - Parsing project file...
2019-05-24 16:57:02.000 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - startIhcListeners
2019-05-24 16:57:02.016 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - IHC resource value listener started
2019-05-24 16:57:02.020 [DEBUG] [nhab.binding.ihc.internal.IhcBinding] - Subscribe resource runtime value notifications
2019-05-24 16:57:02.029 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - IHC controller state listener started
2019-05-24 16:57:02.032 [DEBUG] [org.openhab.binding.ihc.ws.IhcClient] - Controller initial state text.ctrl.state.ready
It seems as the binding downloads config fine, but the binding is not shown as installed in the PaperUI.
Should I do some more tweaks?
The version I use if from Pauli dated in marts (if I remember correctly). I use 2.5M1 build 1575.
Cant you see IHC/Elko in PaperUI under things?
Nope
I downloaded “org.openhab.binding.ihc-2.4.0-SNAPSHOT” and this works fine.
It pops up in PaperUI
