Hello, I have been using OpenHAB 1.X for a while with good results. Now I have taken the plunge and migrated to OH2. However I am struggling to get a working UDP string input working. In the log file, I get the following lines:
We will accept data coming from the remote end /127.0.0.1:5000
… Unrelated stuff…
Received data G9OFF from an undefined remote end /127.0.0.1:5000. We will not process it
No channel is active or defined for the data we received from /127.0.0.1:5000. It will be discarded.
The item definition is:
String udpIn “[%s]” (All) {udp="<[127.0.0.1:5000:‘REGEX((.*))’]"}
I have addressmask set to true in udp.cfg.
This is on a Raspberry Pi 2. I have a daemon interfacing with some devices, feeding data to OH through a UDP port. The really strange thing is, if I restart everything, it will sometimes work correctly!
Any clues??
Thanks,
Pete
