Installed OH 2.3 on Raspberry via the embedded Raspbian image o.s.
I’m asked at every boot to login with the openhabian credentias
I wonder if there’s a way to automated this process, usefull in some cases, accindentally reboot for example
Maybe I’m wrong and the username/password required at the end of the Raspberry boot is only for the Raspberry itself and not to make the openhab services finishing their startup process?
Ok, now it’s more clear and safe but…
What’s the matter with the fact the at the end of boot it stuck with a username and password request?
By the way, it’s only after entering these credentials that system return the splash information with configuration info (ip for example) and the suggested url to access by
There is nothing wrong with that. It’s standard and how almost every computer works unless you go out of your way to configure it to automatically log in. Nothing is wrong.
Correct, because that information is part of the script that runs when the openhabian user logs in. If there were another login on the system it might show something else.
