Hey
i’m trying to run a bash script in an interval of X seconds.
My script does work without a problem but when i try to execute it with openhab with this .thing part
Thing exec:command:btf [command="sudo /home/openhabian/bt.sh", interval=6, timeout=120 ]
and then let it display as a String in PaperUI
String output "[%s]" { channel="exec:command:btf:output" }
i only get this answer
We trust you have received the usual lecture from the local SystemAdministrator. It usually boils down to these three things: #1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility.sudo: no tty present and no askpass program specifiedWe trust you have received the usual lecture from the local SystemAdministrator. It usually boils down to these three things: #1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility.sudo: no tty present and no askpass program specified
if i run the command in the terminal all is working without a problem and i get the right result which is ON / OFF as an echo.
Also tried it without sudo then its always showing “OFF” even tho if i then manually run the script i get “ON”
