I’m sorry but we are getting a ton of threads lately with people corrupting there jsondb. This has not been the case since I’ve been around (year - year & 1/2) and I’m beginning to think something is up
What would the point be to backing up 0 byte backups?
I can see you general thought but should you backup your backup of your backup and where does it end?
I can live the general MTBF of memories, CPUs and so on but I have a hard time living with a system that just stops working and removes everything you’ve done and then creates backups with no data in them
Do you still have the log files from around and before that time? Otherwise it will be just wild guesses and/or good advice about future backup strategies…
And to be sure: are you running on a Pi with an SD card?
It’s actually not all backups that is empty, just the ones for Things.
I’ll redo everything but would very much like to help and solve this problem, it’s quite a significant issue if you want to keep more novis users. Have everything reset like this is not spiking my enthusiasm
The log files are in the /etc/openhab/userdata/logs directory (if you used the openHABian installation), they are called openhab.log and events.log. Look in openhab.log for [WARN] and [ERROR] entries around and before that time, for starters.
Can’t make it undone and tell why it went to 0 bytes but can tell what’s the first things you should do to be prepared this does not happen again.
You should a) setup a backup (preferrably use openHABian and Amanda), b) increase the number of copies jsondb takes which is 5 by default. You can do this in PaperUI under Configuration - System
And c) take regular config backups using openhab-cli backup (eventually setup a cronjob).
