Ok i spent my second night readings lots of info on the subject without any success. I think i really need another person viewing the code to see something!
So my problem is that openhab doesn’t seem to communicate with mosquitto at all.
My setup is really simple:
Openhab2 and mosquitto installed on the same server (ubuntu)
My desktop to test (subscribe and publish)
An arduino board that only publish a string
They are all on the same network. From my desktop i see my arduino message. From my server i see both arduino and desktop message. But i never saw anything coming from my OH2 and OH2 don’t see any message. I’m able to see the arduino and desktop connecting on mosquitto log, but i don’t see my OH2 connecting.
In the karaf log i’ve put debug logging on org.openhab.io.transport.mqtt and org.openhab.binding.mqtt.
here’s the log (i clicked on my switch to get the last line there) :
openhab> log:tail | grep mqtt
22:41:19.056 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
22:41:19.059 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=200, service.id=319, service.bundleid=201, service.scope=bundle} - org.openhab.io.transport.mqtt
22:41:19.086 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
22:41:19.123 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
22:41:19.637 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
22:41:19.638 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
22:41:19.640 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
22:41:20.119 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
22:41:20.126 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
22:41:20.158 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'arduinoTest' : 1 subscribers, 0 publishers
22:41:20.170 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'openhabtest' : 0 subscribers, 2 publishers
22:41:20.171 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'humidityTest' : 1 subscribers, 0 publishers
22:41:20.176 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=213, service.id=340, service.bundleid=213, service.scope=bundle} - org.openhab.binding.mqtt
22:41:20.207 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
22:41:20.209 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=214, service.id=342, service.bundleid=213, service.scope=bundle} - org.openhab.binding.mqtt
22:41:20.227 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=215, service.id=343, service.bundleid=213, service.scope=bundle} - org.openhab.binding.mqtt
22:41:20.228 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
22:48:51.327 [DEBUG] [inding.mqtt.internal.MqttItemBinding] - Publishing command ON to test/openhab
I never saw the famous line : Starting MQTT broker connection …
I tired this without success :
delete file: /var/lib/openhab2/config/org/openhab/mqtt.config and let openHAB 2 reload your /etc/openhab2/services/mqtt.cfg
Here’s pretty much all my config related to it that i know of…
mqtt.cfg:
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mosquitto.url=tcp://localhost:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a default one is generated.
mosquitto.clientId=openhab
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
mosquitto.retain=false
# Optional. True or false. Defines if messages are published asynchronously or
# synchronously. Defaults to true.
mosquitto.async=true
# Optional. Defines the last will and testament that is sent when this client goes offline
# Format: topic:message:qos:retained <br/>
#<broker>.lwt=<last will definition>
addons.cfg (binding section):
# A comma-separated list of bindings to install (e.g. "sonos,knx,zwave")
binding = mqtt1,weather,nest,mios1,xbmc,zwave
# A comma-separated list of UIs to install (e.g. "basic,paper")
ui = paper,habmin,habpanel,basic,classic
# A comma-separated list of persistence services to install (e.g. "rrd4j,jpa")
persistence = rrd4j,mqtt,mapdb
# A comma-separated list of actions to install (e.g. "mail,pushover")
action = mios,mqtt,xbmc
karaf mqtt config:
openhab> config:edit org.openhab.mqtt
openhab> config:property-list
mosquitto.async = true
mosquitto.clientId = openhab
mosquitto.retain = false
mosquitto.url = tcp://localhost:1883
service.pid = org.openhab.mqtt
karaf features:
openhab> feature:list | grep mqtt
esh-io-transport-mqtt | 0.9.0.b5 | | Started | distro-2.1.0 |
openhab-transport-mqtt | 2.1.0 | x | Started | distro-2.1.0 | MQTT Transport
openhab-action-mqtt | 1.10.0 | x | Started | addons-2.1.0 | MQTT Action
openhab-binding-mqtt1 | 1.10.0 | x | Started | addons-2.1.0 | MQTT Binding
openhab-binding-mqttitude1 | 1.10.0 | | Uninstalled | addons-2.1.0 | OwnTracks (formerly MQTTitude) Binding
openhab-persistence-mqtt | 1.10.0 | x | Started | addons-2.1.0 | MQTT Persistence
openhab-action-mqtt | 1.10.0 | x | Started | openhab-addons-2.1.0 | MQTT Action
openhab-binding-mqtt1 | 1.10.0 | x | Started | openhab-addons-2.1.0 | MQTT Binding
openhab-binding-mqttitude1 | 1.10.0 | | Uninstalled | openhab-addons-2.1.0 | OwnTracks (formerly MQTTitude) Binding
openhab-persistence-mqtt | 1.10.0 | x | Started | openhab-addons-2.1.0 | MQTT Persistence
items (all three are for testing for the moment):
String arduinoTest "Arduino Test: [%s]" (gArduino) {mqtt="<[mosquitto:arduino:state:default]"}
Switch openhabtest "Openhab Test: [%s]" (gArduino) {mqtt=">[mosquitto:test/openhab:command:ON:1],>[mosquitto:test/openhab:command:OFF:0]"}
Number humidityTest "hum [%.d]" (gArduino) {mqtt="<[mosquitto:hum:state:default]"}
I’m using my sitemap to toggle the switch.
