NCO
(E. Gerland)
June 28, 2018, 2:28pm
1
I see in my log:
2018-06-28 16:19:11.324 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-06-28 16:19:11.796 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-habpanel'
Then a little later:
2018-06-28 16:20:22.006 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
and:
2018-06-28 16:21:26.514 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-06-28 16:21:27.080 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-habpanel'
I checked my addons.cfg:
# A comma-separated list of UIs to install (e.g. "basic,paper")
ui = basic,paper,habmin,habpanel
sihui
(SiHui)
June 28, 2018, 4:57pm
2
Check your /userdata/config/org/openhab/addons.config if it has different content.
If yes edit it or delete the whole file and restart openHAB, the addons.config will be recreated.
NCO
(E. Gerland)
June 29, 2018, 5:13am
3
Thanks, I did not even know that these files exist?
Would it make sense to delete all of them to clean up like deleting the cache after an update?
Because I also have some issues with persistence…
sihui
(SiHui)
June 29, 2018, 6:43am
4
It should not harm the system, but actually this little “bug” has been solved for all *.cfg files if you put an additional line as first line in your file:
pid:org.openhab.addons
More about this can be found here:
EDIT: Uninstall the wifiled binding using the openHAB console and the command: bundle:uninstall org.openhab.binding.wifiled
Another workaround:
check the contents of: $OPENHAB_USERDATA/config/org/openhab/addons.config (/var/lib/openhab2/config/org/openhab/addons.config)
You can set the desired addons in your $OPENHAB_CONF/services/addons.cfg (/etc/openhab2/services/addons.cfg)
To explicitly load what config you define in addons.cfg, use: pid:org.openhab.addons as the first line in $OPENHAB_…
NCO
(E. Gerland)
June 29, 2018, 7:58am
5
sihui:
Thanks; I’ve put it in the top line of my addons.cfg and will monitor the situation.
