I’m running the harmony binding and it works well. The problem is that after som minutes it starts to fill my log with these error messages. Running the latest nightly of OH2.
I’m running 3 Harmony Hubs in my house.
I I restart OH2 the errors disappear for a while before they start again.
What could be wrong?
2017-01-01 09:24:56.109 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
java.io.EOFException: no more data available - expected end tag </stream:stream> to close start tag <stream:stream> from line 1, parser stopped on END_TAG seen ...<![CDATA[result=-1]]></oa></iq>... @1:640
at org.xmlpull.mxp1.MXParser.fillBuf(MXParser.java:3035)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.xmlpull.mxp1.MXParser.more(MXParser.java:3046)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1144)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.jivesoftware.smack.tcp.PacketReader.parsePackets(PacketReader.java:279)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.jivesoftware.smack.tcp.PacketReader.access$000(PacketReader.java:47)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.jivesoftware.smack.tcp.PacketReader$1.run(PacketReader.java:81)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
2017-01-01 09:25:00.158 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
2017-01-01 09:25:06.459 [WARN ] [.jivesoftware.smack.tcp.PacketWriter] - Exception writing closing stream element
java.net.SocketException: Connection reset
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:113)[:1.8.0_111]
at java.net.SocketOutputStream.write(SocketOutputStream.java:153)[:1.8.0_111]
at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)[:1.8.0_111]
at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)[:1.8.0_111]
at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)[:1.8.0_111]
at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)[:1.8.0_111]
at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)[:1.8.0_111]
at java.io.BufferedWriter.flush(BufferedWriter.java:254)[:1.8.0_111]
at org.jivesoftware.smack.tcp.PacketWriter.writePackets(PacketWriter.java:190)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.jivesoftware.smack.tcp.PacketWriter.access$000(PacketWriter.java:40)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
at org.jivesoftware.smack.tcp.PacketWriter$1.run(PacketWriter.java:77)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
2017-01-01 09:25:06.460 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
stream:error (resource-constraint) text: MAX_CLIENTS=6
at org.jivesoftware.smack.tcp.PacketReader.parsePackets(PacketReader.java:214)[192:org.openhab.binding.harmonyhub:2.0.0.201612291742]
2017-01-01 09:25:08.894 [WARN ] [rg.jivesoftware.smack.XMPPConnection] - Connection closed with error
