i am trying to configure OH2 (2.0.0-SNAPSHOT, Build #444) to connect to an homegear running on the same PC. It looks like it is online but it can’t register the callback. There are logs on the OH2 like
2016-08-10 11:21:59.985 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC server
2016-08-10 11:21:59.985 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9125
2016-08-10 11:22:00.510 [DEBUG] [ternal.communicator.HomematicGateway] - New device 'LTK0044054' detected on gateway with id '393cc853'
2016-08-10 11:22:00.571 [DEBUG] [ternal.communicator.HomematicGateway] - Loaded device 'LTK0044054' (HM-PB-2-WM55-2) with 29 datapoints
2016-08-10 11:22:34.216 [WARN ] [o.myopenhab.internal.MyOpenHABClient] - Jetty request 2685 failed: null
2016-08-10 11:22:59.990 [INFO ] [ternal.communicator.HomematicGateway] - No event since 1020 seconds from gateway '393cc853', restarting RPC server
2016-08-10 11:22:59.999 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC server
2016-08-10 11:23:00.000 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9125
2016-08-10 11:23:00.525 [DEBUG] [ternal.communicator.HomematicGateway] - New device 'LTK0044054' detected on gateway with id '393cc853'
2016-08-10 11:23:00.592 [DEBUG] [ternal.communicator.HomematicGateway] - Loaded device 'LTK0044054' (HM-PB-2-WM55-2) with 29 datapoints
2016-08-10 11:24:00.005 [INFO ] [ternal.communicator.HomematicGateway] - No event since 1080 seconds from gateway '393cc853', restarting RPC server
2016-08-10 11:24:00.009 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC server
2016-08-10 11:24:00.010 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9125
2016-08-10 11:24:00.533 [DEBUG] [ternal.communicator.HomematicGateway] - New device 'LTK0044054' detected on gateway with id '393cc853'
2016-08-10 11:24:00.600 [DEBUG] [ternal.communicator.HomematicGateway] - Loaded device 'LTK0044054' (HM-PB-2-WM55-2) with 29 datapoints
2016-08-10 11:25:00.014 [INFO ] [ternal.communicator.HomematicGateway] - No event since 1140 seconds from gateway '393cc853', restarting RPC server
2016-08-10 11:25:00.019 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC serve
2016-08-10 11:25:00.020 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9125
2016-08-10 11:25:00.542 [DEBUG] [ternal.communicator.HomematicGateway] - New device 'LTK0044054' detected on gateway with id '393cc853'
2016-08-10 11:25:00.605 [DEBUG] [ternal.communicator.HomematicGateway] - Loaded device 'LTK0044054' (HM-PB-2-WM55-2) with 29 datapoints
2016-08-10 11:26:00.024 [INFO ] [ternal.communicator.HomematicGateway] - No event since 1200 seconds from gateway '393cc853', restarting RPC server
2016-08-10 11:26:00.029 [DEBUG] [nal.communicator.server.BinRpcServer] - Stopping BIN-RPC server
2016-08-10 11:26:00.030 [DEBUG] [nal.communicator.server.BinRpcServer] - Initializing BIN-RPC server at port 9125
2016-08-10 11:26:00.553 [DEBUG] [ternal.communicator.HomematicGateway] - New device 'LTK0044054' detected on gateway with id '393cc853'
2016-08-10 11:26:00.619 [DEBUG] [ternal.communicator.HomematicGateway] - Loaded device 'LTK0044054' (HM-PB-2-WM55-2) with 29 datapoints
And this on the homegear:
08/10/16 11:25:00.020 RPC Server (Port 2001): Info: Client number 5516 is calling RPC method: init (2) Parameters:
(String) binary://192.168.178.50:9125
(String) RF-393cc853
08/10/16 11:25:00.021 Info: Adding server "binary://192.168.178.50".
08/10/16 11:25:00.021 Info: Calling init methods on server "binary://192.168.178.50".
08/10/16 11:25:00.024 RPC Server (Port 2001): Info: Connection to client number 5516 closed (3).
08/10/16 11:25:00.122 RPC Server (Port 2001): Info: Connection from 127.0.0.1:59227 accepted. Client number: 5522
08/10/16 11:25:00.123 RPC Server (Port 2001): Info: RPC server client id for client number 5522 is: 919
08/10/16 11:25:00.123 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/10/16 11:25:00.521 RPC client: Info: Calling RPC method "system.listMethods" on server binary://192.168.178.50.
08/10/16 11:25:00.542 RPC client: Info: Calling RPC method "newDevices" on server 192.168.178.50.
08/10/16 11:25:00.544 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: listDevices (2) Parameters:
08/10/16 11:25:00.566 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getDeviceInfo (2) Parameters:
08/10/16 11:25:00.587 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) LTK0044054:0
(String) MASTER
08/10/16 11:25:00.590 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) VALUES
08/10/16 11:25:00.594 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) LTK0044054:1
(String) MASTER
08/10/16 11:25:00.597 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) VALUES
08/10/16 11:25:00.600 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) LTK0044054:2
(String) MASTER
08/10/16 11:25:00.602 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: getParamsetDescription (2) Parameters:
(String) VALUES
08/10/16 11:25:15.126 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/10/16 11:25:30.129 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/10/16 11:25:45.133 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/10/16 11:26:00.026 RPC Server (Port 2001): Info: Client number 5522 is calling RPC method: init (2) Parameters:
08/10/16 11:26:00.026 Info: Removing server "binary://192.168.178.50".
And this is repeating…
Anybody an idea what the problem could be?
Thanks, Jens
