in OH2 I have an Error Message with an Hue Bulb
2016-12-14 11:58:24.446 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Kamin’ to handler for channel ‘hue:0210:00178810164f:5’, because no thing with the UID ‘hue:0210:00178810164f’ could be found.
2016-12-14 11:58:50.351 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Kamin’ to handler for channel ‘hue:0210:00178810164f:5’, because no thing with the UID ‘hue:0210:00178810164f’ could be found.
2016-12-14 11:58:50.353 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘80,100,57’ for item ‘cKamin’ to handler for channel ‘hue:0210:00178810164f:5’, because no thing with the UID ‘hue:0210:00178810164f’ could be found
When I look in the console I see that the problem is, that Kamin has two links, one is with color in the end and the other not…
Also smarthome:links clear does not help…
openhab> smarthome:links
Kamin -> hue:0210:00178810164f:5
cKamin -> hue:0210:00178810164f:5
hSofaecke -> hue:0200:00178810164f:10:color_temperature
Sofa -> hue:0210:00178810164f:1:color
cSofa -> hue:0210:00178810164f:1:color
hSofa -> hue:0210:00178810164f:1:color_temperature
TV -> hue:0210:00178810164f:2:color
cTV -> hue:0210:00178810164f:2:color
hTV -> hue:0210:00178810164f:2:color_temperature
Kamin -> hue:0210:00178810164f:5:color
cKamin -> hue:0210:00178810164f:5:color
hKamin -> hue:0210:00178810164f:5:color_temperature
How can I delete these two entries ?
Regards
Jörg
