Hello community,
i am trying to get my head around a problem i seem to have in my new testing environment, i am trying to move from OH 1.8.3 (which runs perfectly in a virtual machine) to a new Raspberry3 with openhabian (thank you very much for this great piece of work!).
Enviroment new:
Raspberry Pi3 with openhabian running openhab2-offline 2.0.0~20161224034628.
knxd 0.11.15 compiled from source connecting via TUNNEL to 10.0.0.200 (a Siemens N148/22), has PA 1.1.20 set (free on bus) and executes read (knxtool read) and write (knxtool groupswrite) commands without delay or error.
KNX Binding 1.9-SNAPSHOT
Some other bindings (like Weather, Astro, ZWave), which i don’t think create the problem.
Starting up OH2, the log shows that the TUNNEL connection to knxd has been established successfully, but when i try to execute a command via basicui, Exceptions from the KNX Binding show up:
Value ‘ON’ could not be sent to the KNX bus
using datapoint ‘command DP 1/2/6 Licht_OG_Arbeitszimmer, DPT main 0 id 1.001, low priority’ - retrying one time: no confirmation reply received for L-Data.req from 1.1.21 to 1/2/6, low priority hop count 6 repeat tpdu 00 81
and then
using datapoint ‘command DP 1/2/6 Licht_OG_Arbeitszimmer, DPT main 0 id 1.001, low priority’ - giving up after second try: no confirmation reply received for L-Data.req from 1.1.21 to 1/2/6, low priority hop count 6 repeat tpdu 00 81
Additionally, the log gets spammed with this message:
Ignoring local Event, received from my local Source address 1.1.21 for Group address 1/2/6
KNX Binding Configuration (services/knx.cfg):
ip=localhost
ignorelocalevents=true
type=TUNNEL
Item (items/beleuchtung.items):
Switch Licht_OG_Arbeitszimmer “Licht OG Arbeitszimmer” (OG_Arbeitszimmer,LichtOG) { knx=“1/2/6+<1/2/7” }
Sitemap (sitemaps/agb9.sitemap):
sitemap agb9 label=“Am Gepringbach 9” {
Frame label=“Test” {
Switch item=Licht_OG_Arbeitszimmer icon=big_bulb
What i don’t understand is that the actor executes the command from the basicui, but the exception still appears in the log. I can even switch the light off again after a few seconds, but not earlier.
I have read through numerous topics on this issue, including (but not limited to):
https://knx-user-forum.de/forum/supportforen/openhab/1025341-doppelte-aktivität-auf-knx-bus
I have seen quite a lot of commotion on the KNX2 Binding, but i want to get this to work the way it works right now with my OH1 before moving on to the newer version.
Can anyone point me in the right direction please?
Best regards,
Alex
