OK. I will try to changed IPs.
In meantime the problem occurred again, here are the logs, maybe it will brings some new ideas about the problem reason:
2018-09-16 07:59:30.052 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - received disconnect response status 0x21 (no active data connection with that ID)
2018-09-16 07:59:30.098 [ERROR] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - close connection - maximum send attempts
tuwien.auto.calimero.KNXAckTimeoutException: maximum send attempts, no service acknowledgment received
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:250) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:178) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:243) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:351) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:222) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:401) ~[266:org.openhab.binding.knx:2.3.0]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:359) ~[266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:444) ~[266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.writeToKNX(AbstractKNXClient.java:410) ~[266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$6(DeviceThingHandler.java:211) ~[266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:121) [266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:115) [266:org.openhab.binding.knx:2.3.0]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.handleCommand(DeviceThingHandler.java:208) [266:org.openhab.binding.knx:2.3.0]
at sun.reflect.GeneratedMethodAccessor1199.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [103:org.eclipse.smarthome.core:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [103:org.eclipse.smarthome.core:0.10.0.oh230]
at com.sun.proxy.$Proxy200.handleCommand(Unknown Source) [266:org.openhab.binding.knx:2.3.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [110:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemFollowProfile.onStateUpdateFromItem(SystemFollowProfile.java:61) [110:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at sun.reflect.GeneratedMethodAccessor214.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [103:org.eclipse.smarthome.core:0.10.0.oh230]
2018-09-16 07:59:31.534 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.knx.internal.handler.DeviceThingHandler@d1bb85’: process communicator detached
java.lang.IllegalStateException: process communicator detached
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:400) ~[266:org.openhab.binding.knx:2.3.0]
2018-09-16 07:59:31.532 [ERROR] [calimero.link.127.0.0.1:3671 ] - send error, closing link
tuwien.auto.calimero.knxnetip.KNXConnectionClosedException: send attempt on closed connection
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:215) ~[266:org.openhab.binding.knx:2.3.0]
2018-09-16 07:59:31.527 [ERROR] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - establishing connection failed, null
2018-09-16 07:59:33.840 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.knx.internal.handler.DeviceThingHandler@f9c648’: process communicator detached
