Muplex
(Muplex)
January 29, 2017, 11:11am
1
I have to notice to the Devs massive problems I encountered with boundle installation.
I’m starting with a brand new debian release. corretly installed and updated
what i see in my sistem is the following things:
sometimes 1.9 binding gives error during installation
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing “ANY 1.9 BINDING”
Only solution I found is to remove OH2 and reinstall.
sometimes all seems OK from the files. Karaf console don’t give any problem BUT 1.9 bindings, like MQTT and Wheather, wont work properly
look at 2 posts solved by me, only re-installing OH2. any other way was unusable,
Hello
here it is my specifications
Installed weather binding from paper UI (not Yahoo) [version weather 1.9]
weather.cfg
#apikey.ForecastIo=
apikey.OpenWeatherMap=0b9xxxx
#apikey.WorldWeatherOnline=
#apikey.Wunderground=
#apikey.Hamweather=
#apikey2.Hamweather=
#apikey.Meteoblue=
location configuration, you can specify multiple locations
location .myhome.name=ZedHome
location.myhome.latitude=45.x
location.myhome.longitude=12.x
location .myhome.woeid=not req
location.myhome.provi…
Hello guys,
I have several problems with the 1.9 bindings to work properly.
Now the problem is with MQTT binding 1.9 on OH2
typing:
openhab> bundle:list
I can see everithing Active, something Resolved and
187 | Resolved | 80 | 1.9.0 | openHAB MQTT Binding 188 | Starting | 80 | 1.9.0 | openHAB MQTT Transport Bundle
Transport Bundle seems stoppend in starting phases. Why ?
Indeed I can see trought Karaf console that MQTT are recived by OpenHAB correcly, bu…
Please Dev, can we try to open a correct issue about these waired behaviur ???
rlkoshak
(Rich Koshak)
January 30, 2017, 3:58pm
2
There is nothing stopping you from opening an issue yourself if you are not seeing one that addresses your issues.
yphyph01
(Yann)
January 31, 2017, 12:40pm
3
Same issue for me since i’ve upgraded from recent snapshot to final release but with thé HTTP binding
Muplex
(Muplex)
January 31, 2017, 12:57pm
4
yphyph01 I thought since1 week about these problem and maybe I solved out the mistery!!
I wanna explain you my tought:
OpenHab2 for install 1.9 binding NEED to create some files inside /etc/openhab2 directory; The default owner and group is openhab:openhab.
One of the first action I (and maybe you also) made is
sudo chown -hR mylinuxuser:mylinuxuser /etc/openhab2
Because I need to edit Items and Sitemap from another PC!!!
These Action prevent Openhab2 to create the 1.9 binding relative files inside /etc/openhab2 folder…and give out missing of installation and several binding errors
Try out these before install
sudo chown -hR openhab:openhab /etc/openhab2
And in the other folders you change the ownership.
Install the binding and all you need and only at the end come back to
Please let me know if I’m right or not!
