migrating from OH1 maxcube binding to OH2 max binding, I’m trying to use all-text files to configure my MAX! devices
like probably any OH1 expert user will try doing.
There’s a number of parameters I need to change (such as exclusive mode and the refresh rate) that can be set via paper UI but not in the max.things file.
@marcel_verpaalen, has this changed meanwhile ?
Or do I need to delete max.things and activate the cube through UI ?
Also, the official doc for the max binding showing the “full” example for max.things didn’t work for me (using yesterday’s OH2 snapshot) because to define things inside a bridge definition apparently does not work ? Had to remove those lines to get it to work.
regards
Markus
