OH2 (build 4) wants to create two connections to MQTT broker although I have only defined one. In services/mqtt.cfg I defined a broker called “localbroker” and later on I decided to rename it in the cfg-file to “openhab”. Since then OH2 always wants to connect to two brokers “localbroker” and “openhab”. When connection “localbroker” tries to connect to the broker, the “openhab” connection stops and so on…
I have tried several times to restart the broker and OH2, and reboot. And I´ve tried to stop the MQTT bundles in the Karaf console, but nothing works.
I don’t know why it still takes the old name “localbroker” from - is it saved in some kind of internal database and how do I get it removed?
Ive read this tread but the suggestions doesn’t help me, although having the exact same problem
Im desperate to get this to work, and Im on the edge to do a complete reinstall of OH2 on the RasPi.
2016-10-23 08:53:56.983 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘openhab’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-10-23 08:53:56.987 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘openhab’
2016-10-23 08:54:03.997 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘localbroker’
2016-10-23 08:54:06.992 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘openhab’
2016-10-23 08:54:08.322 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
Connection lost (32109) - java.io.EOFException
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146)[203:org.eclipse.paho.client.mqttv3:1.0.2]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267)[:1.8.0_65]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65)[203:org.eclipse.paho.client.mqttv3:1.0.2]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107)[203:org.eclipse.paho.client.mqttv3:1.0.2]
… 1 more
2016-10-23 08:54:08.326 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘localbroker’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-10-23 08:54:08.328 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘localbroker’
2016-10-23 08:54:18.335 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘localbroker’
2016-10-23 08:54:18.360 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
… 1 more
2016-10-23 08:54:18.365 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘openhab’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-10-23 08:54:18.375 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘openhab’
2016-10-23 08:54:21.319 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘localbroker’
2016-10-23 08:54:28.377 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘openhab’
2016-10-23 08:54:28.402 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
… 1 more
2016-10-23 08:54:28.409 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘localbroker’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2016-10-23 08:54:28.413 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘localbroker’
