I am a OH1 user… and eventually… through quite extensive support from the community (I will be forever grateful) managed to get a simple, though large system to work in OH1.
In August 2017 I took the plunge, bought a rPi3 and installed openHabian… beautiful installation script/work… and ended up on a web page which said something like: Select habmin, ClassiUI, PaperUI, some other interface, some other interface… and this is where this new experience ended.
I could not make a decision on the spot, and subsequent reading on the forum ended with frustration, due to descriptions like (and I am only paraphrasing) if you migrate from 1 to 2 use this interface, but then you can’t manage things; and some things (or whatever their name) need text config, and when you use text config, some other interface does not work, and you need to use another interface. – What?!
As life has it: I went back to work in September, until yesterday, when I quit my job Hence, I have time again to look my OH environment. Well, work did not help that cause, as I have forgotten most of it due to inactivity in reading and configuring my OH1 system.
And here eventually my query: Has, since the release of OH2, been a development of sort, which allows for a single way (interface) to set-up OH2 and manage its configuration?
I am happy to start fresh, but only want to learn one interface, or one way of doing things. Is this now possible? Maybe 3 months (since August), did not change much. Or is there a plan to consolidate the interfaces into one; or should I wait some time for this consolidation to occur? Is it planned at all?
Where could I find a roadmap for OH2 development?
Any hints appreciated. Thanks.
