recently I updated my OpenHAB server to the latest beta version (beta5) using apt-get. Now, my installation doesn’t start anymore when booting… I also tried to start the init script manually using sudo /etc/init.d/openHAB-service start
but this also didn’t works. it’s just saying Starting openHAB runtime
but nothing happens.
The wrapper.log shows:
DEBUG | wrapper | 2016/12/27 16:32:52 | Classpath element, wrapper.java.classpath.1, does not match any files: /usr/share/openhab2/runtime/karaf/lib/boot/*.jar
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[0] : /opt/jre/jre1.8.0_102/bin/java
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[1] : -Dkaraf.home=/usr/share/openhab2/runtime/karaf
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[2] : -Dkaraf.base=/var/lib/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[3] : -Dkaraf.data=/var/lib/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[4] : -Dkaraf.etc=/usr/share/openhab2/runtime/karaf/etc
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[5] : -Dcom.sun.management.jmxremote
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[6] : -Dkaraf.startLocalConsole=false
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[7] : -Dkaraf.startRemoteShell=true
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[8] : -Djava.endorsed.dirs=/opt/jre/jre1.8.0_102/jre/lib/endorsed:/opt/jre/jre1.8.0_102/lib/endorsed:/usr/share/openhab2/runtime/karaf/lib/endorsed
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[9] : -Djava.ext.dirs=/opt/jre/jre1.8.0_102/jre/lib/ext:/opt/jre/jre1.8.0_102/lib/ext:/usr/share/openhab2/runtime/karaf/lib/ext
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[10] : -Dopenhab.home=/usr/share/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[11] : -Dopenhab.conf=/etc/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[12] : -Dopenhab.runtime=/usr/share/openhab2/runtime
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[13] : -Dopenhab.userdata=/var/lib/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[14] : -Dopenhab.logdir=/var/log/openhab2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[15] : -Dorg.osgi.service.http.port=8080
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[16] : -Dorg.osgi.service.http.port.secure=8443
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[17] : -Xmx256m
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[18] : -Djava.awt.headless=true
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[19] : -XX:+UseG1GC
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[20] : -Dkaraf.instances=/usr/share/openhab2/runtime/karaf/instances
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[21] : -Dkaraf.restart.jvm.supported=true
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[22] : -Djava.io.tmpdir=/var/lib/openhab2/tmp
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[23] : -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[24] : -Djava.library.path=/usr/share/openhab2/runtime/karaf/lib/wrapper/
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[25] : -classpath
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[26] : /usr/share/openhab2/runtime/karaf/lib/wrapper/karaf-wrapper.jar:/usr/share/openhab2/runtime/karaf/lib/wrapper/karaf-wrapper-main.jar
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[27] : -Dwrapper.key=bXFp4IjWAzH4vCY8
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[28] : -Dwrapper.port=32000
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[29] : -Dwrapper.jvm.port.min=31000
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[30] : -Dwrapper.jvm.port.max=31999
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[31] : -Dwrapper.debug=TRUE
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[32] : -Dwrapper.pid=2593
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[33] : -Dwrapper.version=3.2.3
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[34] : -Dwrapper.native_library=wrapper
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[35] : -Dwrapper.service=TRUE
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[36] : -Dwrapper.cpu.timeout=10
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[37] : -Dwrapper.jvmid=2
DEBUG | wrapper | 2016/12/27 16:32:52 | Command[38] : org.apache.karaf.wrapper.internal.service.Main
STATUS | wrapper | 2016/12/27 16:32:52 | Launching a JVM...
INFO | jvm 2 | 2016/12/27 16:32:53 | Error: Could not find or load main class org.apache.karaf.wrapper.internal.service.Main
DEBUG | wrapper | 2016/12/27 16:32:53 | Signal trapped. Details:
DEBUG | wrapper | 2016/12/27 16:32:53 | signal number=17 (SIGCHLD), source="unknown"
DEBUG | wrapper | 2016/12/27 16:32:53 | Received SIGCHLD, checking JVM process status.
DEBUG | wrapper | 2016/12/27 16:32:53 | JVM process exited with a code of 1, setting the wrapper exit code to 1.
ERROR | wrapper | 2016/12/27 16:32:53 | JVM exited while loading the application.
DEBUG | wrapper | 2016/12/27 16:32:53 | JVM was only running for 0 seconds leading to a failed restart count of 2.
DEBUG | wrapper | 2016/12/27 16:32:53 | Waiting 5 seconds before launching another JVM.
Currently I’m starting OpenHAB manually after startup using:
sudo /usr/share/openhab2/runtime/bin/start
OR
sudo /usr/share/openhab2/start.sh
This works as a temporary workaround… Maybe someone has an idea who I can fix the descripted problem.
Thanks,
Michel
