Log part 2:
2018-04-17 15:47:17.958 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:17.958 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
networkInterface=java.net.MulticastSocket@6af8e1ce
2018-04-17 15:47:18.172 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
at java.net.PlainDatagramSocketImpl.send(Native Method) ~[?:?]
at java.net.DatagramSocket.send(DatagramSocket.java:693) [?:?]
at org.jupnp.transport.impl.DatagramIOImpl.send(DatagramIOImpl.java:156) [181:org.jupnp:2.3.0]
at org.jupnp.transport.impl.DatagramIOImpl.send(DatagramIOImpl.java:149) [181:org.jupnp:2.3.0]
at org.jupnp.transport.RouterImpl.send(RouterImpl.java:300) [181:org.jupnp:2.3.0]
at org.jupnp.protocol.async.SendingSearch.execute(SendingSearch.java:90) [181:org.jupnp:2.3.0]
at org.jupnp.protocol.SendingAsync.run(SendingAsync.java:52) [181:org.jupnp:2.3.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
at java.lang.Thread.run(Thread.java:745) [?:?]
2018-04-17 15:47:18.172 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:18.173 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:18.461 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
2018-04-17 15:47:18.462 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:18.462 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:18.676 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
2018-04-17 15:47:18.677 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:18.677 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:18.968 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
2018-04-17 15:47:18.969 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:18.969 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:19.108 [INFO ] [netatmo.handler.NetatmoBridgeHandler] - Initializing API Connection and scheduling token refresh every 5400s
2018-04-17 15:47:19.474 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
2018-04-17 15:47:19.476 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:19.476 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:19.978 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Exception sending datagram to: /239.255.255.250: java.io.IOException: No route to host (sendto failed)
2018-04-17 15:47:19.979 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: datagram.socketAddress=/239.255.255.250:1900, length=94, offfset=0, data.bytes=94
2018-04-17 15:47:19.979 [ERROR] [.jupnp.transport.impl.DatagramIOImpl] - Details: socket=false, closed=true, bound=null, inetAddress=null, remoteSocketAddress=name:0.0.0.0,
2018-04-17 15:47:20.254 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.xxx.xxx:1012
2018-04-17 15:49:35.783 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx, base URL =
http://localhost:8080)
2018-04-17 15:56:35.820 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-04-17 15:57:01.957 [INFO ] [tatmo.internal.WelcomeWebHookServlet] - Netatmo webhook servlet stopped
2018-04-17 15:57:02.010 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-04-17 15:57:02.024 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx, base URL =
2018-04-17 15:57:02.208 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-04-17 15:57:02.214 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-04-17 15:57:02.219 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-04-17 15:57:02.226 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
